Polk CSi5 sound
I just received a CSi5. Upgraded from a CS2. I don't hear a difference. Do I need to re-calibrate with my pioneer receiver in order to hear a difference? Everything I have read said that the CSi5 is awesome.
Maybe I'm doing something wrong but whenever I auto calibrate, the speaker levels are really low and the speaker distances are usually way off. Any help and suggestions would be greatly appreciated.
Pioneer sc-07
center-CSi5
fronts-RTi8
Surrounds-Polk FXi A4
sub-Paradigm DSP 3200
    txcoastal1 Posts: 13,519
    When you are calibrating are you turning off heat/air, fans etc
  • dizzy
    dizzy Posts: 91
    Yes. I try to make it as quiet as possible. The levels usually end up being -2 or lower.
    Pioneer sc-07
    center-CSi5
    fronts-RTi8
    Adjust those levels back up. Start with your front 3 set to 0 and balance it out yourself from the listening position. Auto calibrations don't always get it right, you still may need to tweak some settings.
  • dizzy
    dizzy Posts: 91
    How accurate does the distance need to be if I adjust the levels manually? I finally have 7.1 and want it to sound the best that I can. Is there a number that the surrounds and surround back should be compared to the front 3? I know they shouldn't be set higher. Or is it all a matter of preference?
    Pioneer sc-07
    center-CSi5
    fronts-RTi8
  • Nightfall
    Nightfall Posts: 10,083
    If you have an Apple or Android device you can download a db meter app. From the sweet spot all speakers should be at the same db, playing a test tone/static.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • dizzy
    dizzy Posts: 91
    By sweet spot, do you mean listening position? I will try that. Thank you.
    Pioneer sc-07
    center-CSi5
    fronts-RTi8
  • rooftop59
    rooftop59 Posts: 8,120
    Yes the best bet is still a tape measure and an SPL meter, which luckily can be had free on your phone or tablet. They are not the most accurate by any means, but are often better than the baked in eq. And yes, take all measurements from the main listening position.
    Game Room 5.1.4:
    Bedroom 2.1
  • Is everything being driven by your AVR?
  • dizzy
    dizzy Posts: 91
    Yes everything is driven by the AVR.
    Pioneer sc-07
    center-CSi5
    fronts-RTi8
  • Maybe running an amp to your front three could help
  • dizzy
    dizzy Posts: 91
    I just put a bid on an Emotiva xpa 5. That should help out a bit.
    Pioneer sc-07
    center-CSi5
    fronts-RTi8
    dizzy wrote: »
    When you run the auto calibration, the mic needs to be in your listening position at ear level. That may mean stacking stuff on the couch or chair to get the mic up that high.
    Also, while the calibration is running, the house needs to be dead quiet. No dogs barking, kids running around, washer or dryer running, outside noises....church quiet.
    Like previously mentioned, you can always change the distances and speaker levels yourself and adjust to your tastes.
  • I have had my best results by removing the furniture and placing the Mic on a tripod in and around the the listening position. Use all positions available. And yes dead quiet is a must.
