Lenco PTP5 Idler Drive Turntable Build
SCompRacer
Aaron's (ALL212) brother Craig called and said he has some good size chunks of walnut for me. The wood is sourced from their dad's property, aged and cut up. It's difficult to find really wide pieces, this one is 15" wide.
I got the crotch walnut for my Bottlehead Eros base from him and really loved the way it looks.
The PTP5 consists of two stainless steel plates that separate the motor from platter bearing. The original Lenco had a one piece stamped top plate. Weather permitting I'll trek to Wisconsin to get the materials and start building. I'll re-use the Advanced Analog MG-1 linear air bearing arm currently on my first Lenco.
Now that I have a speed controller (Phoenix Engineering 25 watt beta) I can proceed. The PTP5 is more conducive to a fixed idler position so if you want 33 and 45, a controller works best.
The build will consist of a Baltic Birch stack topped and wrapped with walnut from the same tree.
The modded top plate from my first diy Lenco L75.
I got the maple with walnut accents to wrap my previous table from Craig too, all from his dad's farm. I got tired of the all black finish. Now I want my table to match my phono pre.
Can't wait to see the next masterpiece.
BlueMDPicker wrote: »Can't wait to see the next masterpiece.
That's going to be absolutely beautiful2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
SCompRacer wrote: »Weather permitting I'll trek to Wisconsin to get the materials and start building.
I'm thinking the next thread could be "Rich Has Wood".
Looks like a very good Winter project, looking forward to the finished product!
Hurry up...........Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
Hurry up...........
I'm trying!
Heat wave today compared to prior days. It was 33F / .55C so I got into the garage to make a mess. Cell phone pics so not the best quality.
I did some corner accents with maple. Arron's brother has a diy corner accent attachment for his table saw.
I used a zero kerf saw to trim maple and sanded it flush.
I made a circle cutter attachment for my router to cut a hole in top to recess the platter part way. I used a fluted bit and it worked great. Going in a circle you hit grain from all directions.
I routed some material out between the corners to follow my Eros phono pre amp base design. I had to do multiple cuts due to the thickness.
Before cutting top hole I attached first layer of Baltic Birch to top plate with screws. After determining where MG-1 arm would go, I positioned platter accordingly and drilled a pilot hole through both so I keep the PTP5 bearing plate in the right place.
With knots I fill them with epoxy then plane the fix flat. Any minor imperfections will be filled with my version of wood color sanding. You apply Tung oil varnish, sand and squeegee the mix into flaws and imperfections. Once dry, sand and repeat until you won't notice it.
This repair held the knot together when I routed out the top hole. I just have some fill to do where I opened up the knot on the edge, where the platter will hide it anyway.
Next up cutting the layers with the PTP5 pattern. When I'm not sure....Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
That's going to be beautimous!
I admire projects like this, wish I had the skills and patience, to do something like this right.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Looking forward to seeing/hearing what becomes of this Rich. How many moons have you owned the PTP5 plate? Know you've had this idea simmering for some time now...Jay
Me too! Lots of stuff here you ain't heard.
Start counting moons ~ April 2012.
