Rti12 And Jumper
Pinktulip7
Pinktulip7 Posts: 249
I DON'T SEE ANY JUMPER BACK OF MY BOTH SPEAKER'S,I ONLY SEE
TWO PAIR SPEAKER INPUT AT THE REAR.I CONECT MY SONY MINI
HIFI STEREO WITH TOP INPUT JUST TO TEST THE SPEAKERS,ITS DON'T SOUND LOUD ENOUGH!!SONY OUTPUT AMP IS 100 W PER CHANEL EVENTHOUGH IT WAS NOT MAKE FOR RTI12 SPEAKER...
WHAT SHOULD I DO?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
  • Willow
    Willow Posts: 11,223
    edited September 2004
    there are no lil brass conectors there between the 2 binding posts ? make your own with speaker wire, and your mini system will take a beating trying to power the 12's
  • Pinktulip7
    There are no brass connector inbetween binding post...how can i get one?
  • Willow
    were did you buy them ?? go back there and ask...
    you could ask polk sutomer service...
    make your own from speaker cable very easy and cheap to do..
    Im sure many of us have some lying around (if it's one size fits all)
