NICE NAD 325BEE integrated amp w remote and upgrade $225
geppy1
Selling NAD 325BEE integrated amp. The amp is in excellent shape and everything works as it should. Includes NAD SR5 system remote ,copy of owners manual and power cord. Unit has been with upgraded of an IEC socket on back so you can use detachable power cords which can make a difference. The 325BEE is highly reviewed and features 7 inputs including a front panel input for an MP3 or whatever. Has preamp out and main amp in jacks as well as bass and treble controls with defeat and a balance control. Also features NADSs Soft Clipping circuit. The 325BEE sounds much bigger then it is. It puts out 50 watts per channel into 8 ohms and over 200 into 2 ohms dynamic.
I have owned almost all NAD integrateds made since 1979 and I think the 325 and 326 BEE are in the top 5 . I cannot tell any difference between the 325 and 326. in sound but the 326 has those burn a hole in retina blue lights and the 325 has soft green lights and metal front panel is metal verse plastic. Asking $225 Thanks
PM for pictures
PM for pictures
Anybody?
