Rear Speaker Placement, thoughts?
I'm needing opinions on rear speaker placement. Did a quick and easy diagram of my "home theater" set up; added the potential rear speakers in the only real place I could put them. Wondering how much it will effect the sound by not having them in equal spots and on 2 different walls? I know Pioneer receivers have the MCACC to dial in the settings and delays. But from personal experience, would you think it would be a waste of time to do them? Should I stick with just my in ceilings and just upgrade those to higher end ones? Wouldn't mind a 7.1 set up, might even add another set of in ceilings towards the front if I ever get around to doing the whole ATMOS thing. Thanks again
Home Theater Setup
  • Receiver - Onkyo TX-RZ1100
  • Mains - Polk RTi A9's
  • External Amps - Outlaw 2200 Monoblocks for L/R/C
  • Center - Polk CSiA6
  • Side Surrounds - Polk FXiA6's
  • Atmos - 4 Polk 80F/X RT's
  • Sub - SVS PC-4000
  • T.V. - LG OLED65C7P
    Mine are a tad off kilter too. Can you move that left rear more to the left ?
    Other than that, I can see your limitations and your choices aren't too promising. Another set of in-ceiling speakers may be the route to go and you can place them anywhere.. Which I might put wider out from the couch beyond the current ones and more to the sides of the couch if not a tad more forward too.
  • I could move the left one farther over if needed. I'm fine with using in ceiling speakers, I'm just curious on which ones I should get? Seeing as I just got a set of LSi's, would it be better to match them up? or does it really matter at that point
    Home Theater Setup
    • Sub - SVS PC-4000
    F1nut Posts: 51,912
    Stick with the in ceiling. Rears don't matter much, just ambient sound.
  • Gatecrasher
    Gatecrasher Posts: 1,538
    Now for the important stuff.
    Let's see that kegerator!
    It looks like one of your rear speakers is right above it?
