Enable carp storm, fire on my command!
Nothing can be set up properly in this room. I am not swapping speakers i just want to hear them positioned differently.tis room is all windows doors and openings to other rooms so there is virtually no choice where stuff goes
afterburnt wrote: »Nothing can be set up properly in this room. I am not swapping speakers i just want to hear them positioned differently.tis room is all windows doors and openings to other rooms so there is virtually no choice where stuff goes
Many of us have those same limitations. You just have to find the right speakers to overcome them.HT SYSTEM-
lsi 9's -
ear buds
afterburnt wrote: »ear buds
Hey ya know.....to some cans are the solution.HT SYSTEM-
lsi 9's -
My 705's required some fiddling with placement. I found moving them forward away from the wall even a few inches helped tremendously. And toes in ever so slightly helped big time. But I get obsessive with things.
I even ran out to homedepot at 930 pm to buy a hole saw so I could run a amp power cord out the back of my rack.
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I guess you don't have a shotgun
I will have some longer cables soon and I will be able to move these speakers out into the open, they will kidda block the front door and the door to the exercise room but I dont use either one very much lol.
afterburnt wrote: »Hey can I disconnect the jumpers and just run the top half?
dont try this at home, it is a waste of effort unless you are trouble shooting a failure. boy did that sound bad
