Carpet Coming Monday!
These are of my audio room....I also built the Mrs. a home office.
Now a need a real audio rack...has anyone bought the Pangea 4 shelf rack on Audio Advisor....it is inexpensive but dont want to buy a piece of junk....
  • Mikey081057
    Mikey081057 Posts: 7,127
    Very nice... Carpet does help dampen room echoes.
    Garage | Polk Monitor 5B's
  • kevhed72
    kevhed72 Posts: 5,126
    The walls are loaded up with Roxul / Mineral Wool instead of fiberglass which makes a huge difference just knocking on the walls with you hand. Roxul is nasty stuff though....
    mhardy6647 Posts: 34,913
    edited November 2015
    Yes it is unpleasant (rock wool, that is) -- I remember (at least I think I remember!) my parents' house & attic was insulated with that stuff; it wasn't pleasant to spend too much time in the attic.
    The room/space looks great!
  • DollarDave
    DollarDave Posts: 2,575
    Good work! What are you putting in for gear?
  • kevhed72
    Polk 703s, NAD 356 integrated, TEAC 1000 CD player, Yammy T1 Tuner, APC H15 power condtioner....I have a 15" Sealed Epik sub. which may or may not be needed for music...may keep the sub in the HT room. I do need a real rack soon...as well as a tuner for streaming music.
  • WagnerRC
    WagnerRC Posts: 2,199
    The mineral wool worked great for me too. Very happy .
  • polk500
    polk500 Posts: 1,171
    Looks real good, that's alot of work did you do it all yourself?
    Cheers, Roger
  • kevhed72
    polk500 wrote: »
    Cheers, Roger
    I did.... I put the kids to work holding up the drywall ceiling while I screwed it in... thanks
  • kevhed72
    DSkip wrote: »
    Congrats! The place looks great. Integrating a subwoofer with those 703's might prove to be a challenge due to the powerful midbass.
    Im thinking of not even messing with a smaller sub and focus on other gear.
  • polk500
    Congrats on the hard work, and I know how hard it is as I've done a few home renos but it is sure a great feeling when it done.
    Cheers, Roger
  • kevhed72
    Carpet is in but I have to cut a bit off the bottom of one door....suggestions?
    Im guessing a skill / circular saw with a fine blade (more teeth...)
  • WagnerRC
    attach a guide to the bottom of the door for the saw edge to follow
  • ken brydson
    ken brydson Posts: 8,980
    WagnerRC wrote: »
    ^This^ I use quick clamps and a 4 ft level. I also suggest masking tape along your cut line. It can help protect from a raggedy finished cut.
  • mrbiron
    mrbiron Posts: 5,712
    WagnerRC wrote: »
    ^This and That^
    The clamps and a straight edge will definitely help an inexperienced cutter from walking all over the place. I even still use them.
    OR, you could jack out the entire basement and re-pour. But that requires a couple hours/days/weeks and a few ten-grand. I'd suggest cutting the door....
  • lightman1
    lightman1 Posts: 10,796
    Does the carpet match the drapes?
    ...... :o
    Looking good, bud. Soon...This has only stoked the coals a bit for me. Thanks for the inspiration.
  • WagnerRC
    KEN I use the same method. thanks
  • polk500
    kevhed72 wrote: »
    You can use a skillsaw with a good blade, to insure you get a clean cut please use a straigth edge and make sure it's clamped well. And of course always double check your measurements.
    Cheers, Roger
  • adb3da
    adb3da Posts: 507
    Do you have any updated pics? I would like to see how this turned out!
  • kevhed72
    Yup, taped bith sides and set up a guide with a longer level and 2 clamps. They came out reaaaaal nice. Plus, I have an extra 3/4" tall piece to re use on the last door to the basement which has almost a 1" gap due how the house was originally framed. I plan on adding this extra piece with screws and glue before painting to cut down on the noise from yelling better half and kids which transmits right to the basement.
