Enable carp storm, fire on my command!
You know I was thinking about how to phrase a question about cables and IC's but I don't figure I can do it diplomatically (without a bunch of **** arising from it). Please PM me with your suggestions regarding the performance of my system.
Thank you in retreat.
Bruce
    Just post the question.....I don't understand anyone being afraid to post an audio question on an audio forum.
  • The worse thing that can happen is X shows up....lol.
    – Kevin Alfred Strom
    gudnoyez Posts: 8,174
    http://m.youtube.com/watch?v=jn-UZwtLfH4
    You should go ahead and have an Open Invitation, and bait our arch nemesis ol X
  • seems you have a good line up already. What's not to like?
  • mikeyb128
    mikeyb128 Posts: 2,885
    I'm telling you man, I wasn't too wowed going from modded lsi15's to 705's. A pair of s1 shot guns woke them right up. They are still transforming as the cables break in.
    2 channel:
    Theater:
  • afterburnt
    afterburnt Posts: 7,892
    My 707's sound muffled compared to the Ushers, what should I do?
    heiney9 Posts: 25,496
    What is your budget? What are you currently using? What gear are you connecting? I see a lot of different stuff in your sig, that's why I ask.
    I have used MIT's for years, starting mid-pack and finally graduating to the Shotgun series. One of the single largest improvements I have made to my rig.
  • afterburnt
    Buget? I have no money left but if I could spend a couple of hundred or so to get an idea where improvement can be had I will give it a try. In another thread I indicated that I don't have MIT money for the time being.
  • afterburnt
    I kind of think that the sub drivers are too much for the "703" top half. Is there a way to balance this? There is nothing really bad about it but I guess there is a lack of coherence in some music. wtf do I know???
  • afterburnt
  • afterburnt
    Hey can I disconnect the jumpers and just run the top half?
    txcoastal1 Posts: 13,519
    afterburnt wrote: »
    The tweets will work but won't work or help with your issue.
    How far do you have them off the wall, are either of the speakers in a corner?
  • afterburnt
    txcoastal1 wrote: »
    afterburnt wrote: »
    Want to disconnect them just to see, not as a solution. Wondered if ti could hurt to run em like that? They are not really in a corner only sort of. Maybe that is the issue because they are both right next to full bookcases and one has a wall/door right behind it.
  • Nightfall
    Nightfall Posts: 10,083
    Can you take a picture?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • afterburnt
    edited November 2015
    I never figured that out. I used to be a tech wiz and now I am pretty lame, very lame when it comes to that stuff. However I never gave it much though because I have no choice on placing the speakers. Description wise: Left and Right are butted up against the bookcases on their respective sides. Behind the left is an open threshold to to dining room (partially blocking said entry). The right side is abuutting a matching bookcase and the doorway is in back of it in between the rack. If nothing else I don't have room for these speakers. I never though about the fact that these are not front or back ported, they are bottom ported so that is 360 degrees.
    You can run tweeter only to see what it's like but power everything down while changing cables, and zero volume. Raise volume slowly and don't over drive.
    What receiver/amp are you using? Is it your AVR?
  • afterburnt
    txcoastal1 wrote: »
    Yammaha AVR via A31
    maybe these speakers need to be out in the open?
    Adjust the bass on the AVR ;)
    Set the AVR at flat
  • afterburnt
    It is at flat. These speakers are just crazy bottoms maybe too much for music
  • afterburnt
    subs are a waste of money with these speakers for HT
    pull them out in the room and see what you think
  • afterburnt
    ok I do have some room to pull them forward but maybe not enough cable. this sucks. kindda like stuffing a five pound sack with ten pounds of...uh stuff
    In order for us to help you better, list the gear being used, cables, and source material. like cd's, mp3's, lossless files. As already suggested, pulling them away from a back wall would be great or avoid cramming them in a corner.
  • afterburnt
    Yamaha RX-A2030*Parasound Halo A-31Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's cd's and flacs
    Bruce even if it's temporary
    Try to get 3' out at least from back wall and 3' from side walls
  • afterburnt
    Tx I cant even try it, not enough cable
    afterburnt wrote: »
    Get longer cables then....see how easy that is ? :)
  • afterburnt
    I am trying to lol. It will b nice to see how ther sound out in the room but they can't stay there regardless.maybe I will put em on skateboards.
    afterburnt wrote: »
    Well, if they can't stay there, than whats the point ?
    Maybe the 707's just aren't your cup of tea ? No shame in that if they aren't.
    It's not fair to the gear (speakers in this case) if you don't/can't set them up properly to perform like they were designed. If you have limited space/placement issues you need to figure out what works best there. It will get very frustrating swapping speakers to find the right fit, unless you enjoy that sort of thing.
