Carpet Coming Monday!
kevhed72
These are of my audio room....I also built the Mrs. a home office.
Now a need a real audio rack...has anyone bought the Pangea 4 shelf rack on Audio Advisor....it is inexpensive but dont want to buy a piece of junk....
Very nice... Carpet does help dampen room echoes.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
The walls are loaded up with Roxul / Mineral Wool instead of fiberglass which makes a huge difference just knocking on the walls with you hand. Roxul is nasty stuff though....
Yes it is unpleasant (rock wool, that is) -- I remember (at least I think I remember!) my parents' house & attic was insulated with that stuff; it wasn't pleasant to spend too much time in the attic.
The room/space looks great!
Good work! What are you putting in for gear?
Polk 703s, NAD 356 integrated, TEAC 1000 CD player, Yammy T1 Tuner, APC H15 power condtioner....I have a 15" Sealed Epik sub. which may or may not be needed for music...may keep the sub in the HT room. I do need a real rack soon...as well as a tuner for streaming music.
The mineral wool worked great for me too. Very happy .
Looks real good, that's alot of work did you do it all yourself?
Cheers, Roger -
I did.... I put the kids to work holding up the drywall ceiling while I screwed it in... thanksLooks real good, that's alot of work did you do it all yourself?
Cheers, Roger
Im thinking of not even messing with a smaller sub and focus on other gear.Congrats! The place looks great. Integrating a subwoofer with those 703's might prove to be a challenge due to the powerful midbass.
Congrats on the hard work, and I know how hard it is as I've done a few home renos but it is sure a great feeling when it done.
Cheers, Roger
Carpet is in but I have to cut a bit off the bottom of one door....suggestions?
Im guessing a skill / circular saw with a fine blade (more teeth...) -
attach a guide to the bottom of the door for the saw edge to follow
^This^ I use quick clamps and a 4 ft level. I also suggest masking tape along your cut line. It can help protect from a raggedy finished cut. -
ken brydson wrote: »
^This and That^
The clamps and a straight edge will definitely help an inexperienced cutter from walking all over the place. I even still use them.
OR, you could jack out the entire basement and re-pour. But that requires a couple hours/days/weeks and a few ten-grand. I'd suggest cutting the door....Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Does the carpet match the drapes?
Looking good, bud. Soon...This has only stoked the coals a bit for me. Thanks for the inspiration. -
KEN I use the same method. thanks
You can use a skillsaw with a good blade, to insure you get a clean cut please use a straigth edge and make sure it's clamped well. And of course always double check your measurements.
Cheers, Roger -
Do you have any updated pics? I would like to see how this turned out!
Yup, taped bith sides and set up a guide with a longer level and 2 clamps. They came out reaaaaal nice. Plus, I have an extra 3/4" tall piece to re use on the last door to the basement which has almost a 1" gap due how the house was originally framed. I plan on adding this extra piece with screws and glue before painting to cut down on the noise from yelling better half and kids which transmits right to the basement.
