Blown tweeter
I have a pair of rta 8tl.. Tested and confirmed its the tweeter. How do I get a new sl2500 tweeter.
Best Answer
    Answer ✓
    The new tweeter will sound a bit different than the old one resulting in an unbalanced sound if you don't replace both.
Answers
  • Telephone Polk's CS department at 1-800-377-7655 and mention you have joined Club Polk or you can contact them at polkcs@polkaudio.com
    Regards, Ken
  • Nightfall
    Nightfall Posts: 10,083
    It would be better if you replaced both tweeters with the new RDO-198 replacements and not just one.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Thanks guys. I will be honest I am not doing so well with money. Is it really important to replace both? Or is it hat solution the nth degree best to do. I need to be frugal. I have not called to know the numbers yet so maybe this is a non issue.
    txcoastal1 Posts: 13,519
    Need to replace both
    The replacements sound a lot better
  • Does anyone know the difference between the RTA 8TL's and the RTA 8T. I just looked on the back of the speakers and saw the tags were different on my pair but the speakers look the same.
