Polk Audio SDA SRS 2.3TL Modification Thread
Tweeter Network -
Clarity Cap ESA
Mundorf Mox Resistors
Jantzen Perfect Lay Inductors
Supra Rondo 13 Awg Internal Wiring, Gold Disconnects
Midbass/SDA Network -
Clarity Cap ESA
Jantzen C Coil SDA Inductors
Other -
Lexan Substrate
Point to point, Supra Rondo 13 Awg
Custom 3D Printed Connector Mount, Personalized
Supra Rondo 13 Awg SDA Cable, Neutrik NL4
  • drumminman
    drumminman Posts: 3,396
    Trey, can you describe the difference in sound quality between the Mills 12 watt and the Mundorf MOX resistors? How about cost difference?
    VR3 Posts: 29,427
    (YMMV)
    Mills - Warmer, but also hides quite a bit of detail, particularly macro details and natural decay, Ive never been a fan of the 12 watt mills. On the flip side, I frequently use the MRC50, the 50 Watt Mills in my projects where the owner wants Duelund performance but the price prohibits it due to quantity needed, etc. Like the Legacy build, using Duelund would have been astronomical, but the MRC50 is the same price of the 12 watt and is extremely clean, clear, detailed and transparent.
    The Mundorf I like because it does not really hide any details, it does lean towards the brighter side of the tonality but it reveals a lot of the macro details you would otherwise miss with the 12 watt Mills (YMMV)
    Mundorf is $2.50 each
    Mills is $5.00 each (12 watt or MRC50)
    I sometimes have to make decisions based on suppliers and space savings, the MRC50 is quite a bit larger than the Mundorf and require a different mounting method which does not really make it ideal for me to use often.
    On a completely different topic, when I had my Super Towers and was combing through resistors, I use the Mills (12w and MRC50), Duelund, Mundorf and a cheap "Eagle" brand resistor and the synergy in that system actually sounded better with the Eagle resistor. So to conclude this message, brand and money aside, sometimes it is good to test different things within your system as certain parts will sound better than others on your system than others and to your ears.
  • Conradicles
    Conradicles Posts: 6,342
    I really like the Mundorf.
    VR3 Posts: 29,427
    I agree Conrad, it is solid.
    Have you ever tried the Mundorf Supreme? I ran it a few times and was always impressed but felt the price point was a bit odd given its competition.
  • drumminman
    Thanks for the comprehensive reply Trey.
    VR3 Posts: 29,427
    Yes sir :D
  • PolkieMan
    PolkieMan Posts: 2,446
    Impressive!
  • ptrooper
    ptrooper Posts: 501
    Can't wait to see the 2.3 Abbot build!
  • machone
    machone Posts: 1,558
    Where is a good place to buy gold quick connects (internal wire to driver or tweeter).
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    pitdogg2 Posts: 27,040
    machone wrote: »
    Picked up mine at auto zone and advanced auto
  • ptrooper
    ptrooper Posts: 501
    can't wait to see the 2.3 Abbot build
  • machone
    I will be rebuilding the crossovers in my 2.3tl's sometime in the near future. I plan to use gimpod's boards. If at sometime in the future I wish to upgrade the internal wiring I assume that the male half of the Mate-N-Lock connectors would need to be ordered so that a new wiring harness could constructed?
    If so how are the wires attached to the pins inside the male connector?
    Crimped? Soldered?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    F1nut Posts: 51,760
    Crimped
  • machone
    I guess that would be the Pro-Crimper III on the Mouser catalog page for $250?
    Forget that!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    F1nut Posts: 51,760
    You don't need anything like that.
  • machone
    Good. The pins and connectors don't cost that much so maybe I will order them along with the headers for x-over boards and figure out the wiring harness later.
    Thanks F1
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
