Polk Audio SDA SRS 2 Modification Thread
VR3
Tweeter Network -
Clarity Cap ESA
Mundorf Mox
Jantzen Inductors
Supra Rondo Internal Wiring, Gold Disconnects
Midbass/SDA Network -
Clarity Cap ESA
Clarity Cap PX/Solen PB400V
Jantzen Inductors
Jantzen C Coil
Point to point, singular molex connection with customized 3D printed connection plate
WBT binding post
15 Ft "Abbot" SDA cable, Supra Quadrax
Aluminum terminal plates
Clarity Cap ESA
Mundorf Mox
Jantzen Inductors
Clarity Cap ESA
Jantzen Inductors
Jantzen C Coil
WBT binding post
Internal wiring and everything finalized
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Great job Vr3!
Thank you
Are these the 1986 version with the 130uf caps?
When I blow it up the biggest caps appear to be 82-85uf with 110 solen hard to tell ....good question. Either way Trey always knocks it out of the park
It is the 86 schematic, but the 130 is wowed in parallel with a 55 uf to be 185uf
