anybody demo the Benchmark AHB2 amp?
any what do you think?
What's up w/ their one year warranty or 5 year if you register and they feel
like honoring it?
For some reason I'm trying to talk myself off the Parasound A21 ledge...
  • tratliff
    tratliff Posts: 1,801
    No feedback on the Benchmark but the parasound a21 is really hard to beat for the price.
  • Thanks tratliff. This seems to be so. As it won't work in my current stand...
    Time in to invest in a good rack.
    Sure is....I did when I got married years ago. ;)
    I'd stick with the Parasound too.
  • my problem is I need two racks w/ those pointy things.
  • chumlie
    chumlie Posts: 8,658
    Brings back memories of Madona with her pointy things. Get the Parasound.
  • Always wear eye protection around pointy things. I agree with the Parasound recommendation.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • ukcolin99
    ukcolin99 Posts: 286
    Hello red
    Notwithstanding I am using wire racks that are ruining my sound....I like the A21, the additional power over the Yamaha (150 vs 250wpc@8ohm) is tangible through the 705's. Paired with P5, no hum/noise at max volume, clean sound, fast start, runs slightly warm same temp regardless of use, looks cool.
    When I ran the A21 through the Yamaha unbalanced to use as a pre I got a hum I could never entirely get rid of. What pre are you going to use?
    Anyone know if using the 12v connect to power up the A21 when I turn the P5 on with the remote in any way harms the A21. Should I be turning them on manually, thanks?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Reviewed in this month's Stereophile by Kal Rubinson and measured by J. Atkinson
  • ukcolin99 & Eric.
    Thanks for the insights!
  • Oh, the pre is going to be a Emo xsp-1.
    It is supposed to produce less noise than the A21, so I'm hopeful on that count.
    I got a deal on it I couldn't refuse. It sounds so good as
    such that it bumped the Vincent out.
    I'm using an Emo XPA-200 and it was never supposed to
    be in my main rig this long but is.
    Hence the need for step up amp wise.
    ukcolin99 wrote: »
    Hello red
    No, it won't harm the amp, that's what it was designed for.
  • WLDock
    WLDock Posts: 3,073
    edited October 2015
    I listened to their DAC2 HGC, AHB2 Amp, and SMS1 monitors at the AXPONA show this year. The system was nice. The sound was a little different from some of the other system I heard that day. There was some sweetness yet some bloom on the blues guitar track they were playing when I was in the room. It was a pretty cool little system and the amp sounds really good on paper....with the limited listening I can't say how the price and performance work out in comparison to the Halo stuff.....but the list was like $7440!
    IMO, for about $3000 less I would go with the DAC2 HGC, an A23, a set of the Focal Aria 906's Bookies to get it done. Then spend the $3K on a couple of subs, wire, stands,music, etc...
    http://img.photobucket.com/albums/v711/WLDock/AXPONA Chicago 2015/P1040395.jpg
    http://forum.polkaudio.com/discussion/167205/2015-axpona-chicago-il-pictures/p1
  • Cool and good info. Thanks!
