Need a good FLEXIBLE power cable
Mikey081057
Mikey081057 Posts: 7,127
edited October 2015 in 2 Channel Audio
For my A21... I have a Pangea AC9... but it is not very FLEXIBLE... Anyone have any suggestions that they are happy with?
Garage | Polk Monitor 5B's
Best Answers
  • Nightfall
    Nightfall Posts: 10,083
    edited October 2015 Answer ✓
    Here is a picture Skip sent me of a WW PC that I'm contemplating. My main concern was/is also flexibility.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • motorhead43026
    motorhead43026 Posts: 4,019
    Answer ✓
    mikeyb128 wrote: »
    That looks super nice. How much are those?
    I guess this is still current, it is from July.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
    gudnoyez Posts: 8,172
    Answer ✓
    Wireworld conditioning power cords. I am using the Stratus 7 currently. Yes, I drink the Audio Thesis Kool-Aid. These cords are flat so they have flex and not much memory.
    I have that same Wireworld PC and of all my PCs it's my favorite quite flexible indeed got mine from that Audio Thesis place.
  • teekay0007
    teekay0007 Posts: 2,288
    Answer ✓
    Nightfall wrote: »
    Nice.... Skip you need to use some masking tape when painting around those outlets...:)
    I noticed that too! B) Or a better suggestion...remove one screw, then the plate and paint away! Let it dry a couple of hours and pop the plate back on. Easy-peasy!
  • mrbiron
    mrbiron Posts: 5,721
    Answer ✓
    mikeyb128 wrote: »
    I have ps audio ac3 power cables
    I run these as well and am very happy with their flexibility.
Answers
    EndersShadow Posts: 17,715
    I've heard that CullenCables are quite flexible and close if not better performance wise....
    I've had that debate a couple times myself. My AC-9's are not exactly easy to work around when cable managing....
  • motorhead43026
    edited October 2015
  • mikeyb128
    mikeyb128 Posts: 2,885
    I have ps audio ac3 power cables. Thick and super flexible. Also MIT z chords are nice and flexible.
    2 channel:
    Theater:
  • mikeyb128
    2 channel:
    Theater:
  • Mikey081057
    Nightfall wrote: »
  • voltz
    voltz Posts: 5,384
    edited October 2015
    Voodoo Power Cables * very flexible and so light weight you will asked what even in there?
    Bought 2 used and love them - the Ultra-Wave is for the Amps and new is about $300
  • DaveHo
    DaveHo Posts: 3,582
    I have the Cullen Cable Gold Series on my amp. Been very happy with the performance & construction. Quite flexible to boot.
    cullencable.com/index.php/products/power-cables/gold-series
  • Mikey081057
    DSkip wrote: »
    I don't worry about the plates. I use an edger. Paint is easy to scrape off. Tape takes a crapton of time. I painted that room, two coats, 20' ceilings and all, in a day. I just haven't gone back to fix it all because there are so many other projects going on, like starting a business. :p
    The Wireworld cables are good, hence their appearance in my product list. Cullen cables are good as well. I can't recommend the Pangea AC-9 cables, but the AC-14SE are great entry level budget cables. I haven't regretted moving from those to the Wireworlds though. Not one bit.
    You wouldn't happen to have a short one laying around that you would be willing to part with... Even if it has paint on it :)
  • breal74
    breal74 Posts: 324
    DSkip wrote: »
    The easiest thing to do is remove the plates before painting. Just my 2 cents.
  • Mikey081057
    So I replaced the AC-9 with an AC-14 I had as a spare. I think will keep the AC-9 in my car for protection... It can do more damage than a 5 D cell maglite.
    I will revisit the decision for the best fit for my rig next weekend. Thanks for all the suggestions.
  • Upstatemax
    Upstatemax Posts: 2,775
    edited October 2015
    breal74 wrote: »
    DSkip wrote: »
    That's the ONLY way to do it...
    I'm the son of a high end contractor. Paint on a receptacle or wall switch, massive sign of someone that does not pay attention to detail. Not where you want to be brother!
    Like it or not, people pay attention to that stuff.
  • Mikey081057
    Received a WIREWORLD Electra7 today. . Seems to do the trick and it's breaking in now. Thanks for the tips polkies!
    DSkip wrote: »
    Please tell me you didn't buy new...
    Unless it's from @DSkip
  • Mikey081057
    DSkip wrote: »
    Yup bought new...just needed to get one quick before I ship out of town again for 6 months.
