Polk Bookshelf Speakers.
I have been looking at Polk RTiA1& Polk TSx220B speakers for my Vintage Kenwood KA-8004 amplifier. The amp is capable to produce 110 watts RMS continuous power, 55 watts per channel operating at 8 ohm. Any information or recommendation as to which would be the best choice for my stereo?
Best Answers
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Answer ✓
    I would think that the RTiA1 would be a very nice match to your vintage Kenwood.
    Keep your eye open on the official Polk ebay site for deals on the RTiA1.
    Answer ✓
    Really hard to say without you hearing both. Also, not many of us have heard this newer line TSX-220B speaker. Spec wise the TSX can go lower to 50 hz, but the RTiAs have more robust tweeters that have a little more detail and resolution and are tougher to blow if you do something questionable, like clip the amp?
    For Home Theater, I'd go with the RtiA-1s. Your Kenwood should have NO problem driving either pair, they're both fairly efficient and 8 ohms.
    I'd try to get my ears on the 220s and see what "you" think of them. Then maybe even come back here and give us a "review"?
    Good luck!
  • felipe
    felipe Posts: 423
    Answer ✓
    +1 on the T50s for your setup if you can fit small towers. I've heard them and they sound pretty darn good for the price.
    My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
Answers
  • Thank you for all giving good advice. You are all leaning me to look into towers now. However, I seem to be having the same problem here finding the right pair. As I mentioned, I'm running a great vintage Kenwood amp HA-8004. It pushes 110 watts RMS and 55 watts per channel at 8 ohms. I've read the reviews of the speakers listed here and find I'm more confused as ever. All reviews rave about the speakers. Naturally, every individual is looking for what they were buying them for and the review is tilted in their favor. Here is what I am looking to achieve;
    1. Solid bass response. Cerwin Vega always seemed to be the master here.
    2. Good highs and mids/clear sounding but not over powering the bass response.
    3. Economy in price but not sound.
    4. Able to handle my Amp
    []Here is what I have been looking at-All POLK;
    1. TSi 500
    2. Monitor 60 Series 2
    3. T50 Series.
    Any comments or recommendations in reference to the above & any other models I should consider?
  • I'm leaning toward the T50's. However, they are 6 ohm speakers. Will they work with my vintage Kenwood KA-8004 amplifier or will they stress the amp? Should I stay with 8 ohm speakers?
    grandpa96 wrote: »
    Your Kenwood should do fine, though ear bleeding levels of volume may not be realized. Vintage gear usually had some well built power supplies in spite of what the wattage ratings suggests.
