Bluesound Node 2
In my endless pursuit of whole house audio nirvana I added a Bluesound Node 2 to my system today.
The Node 2 has some nice new features coax digital out, built in Blutooth 4.0 and upgraded processor and ethernet.
I like this low profile version as it racks nicely.
Very nice product and the Node and Node 2 can sync wirelessly and source multiple systems in your network.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
I have used PC with JRiver (nice sound but made my back hurt as I had to stand over the pc while messing with it).
I have a Logitech SB Touch. Which i bought used while my back was hurting from the PC/JRiver combo. My only negative on the SB Touch is that i had to spend a lot of time maintaining/hacking it which worked great but it was cutting in to my limited listening time.
I then purchased a DefTech WAdapt... Which now lives in my WCloset. nuff said. I don't think Deftech is committed to the product as they are very slow to "adapt" to some of the new streaming services (Tidal for example). Their original marketing shpiel was that they would be adopting Tidal but when I talked to them about "when" they talked about "if ever".
Started doing some research for a streamer that would do everything I wanted and came across the Node. The Node's SQ features, services and User Interface all fit my requirements.
The Node2 is just an improvement over the Node and is still compatible using multiple Node family products as part of a whole house system.
I am using the Node2's digital coax output into my Marantz SA8004 SACD players coax input.Setup can be done in less than 5 minutes.
The 8004's analog outs are feeding the Parasound P5 pre which feeds the Parasound A21 via balanced interconnects. There are my setup options, this I feel is my best option taking advantage of the SA8004s DAC. I might try going digital coax directly to the P5 shortening the signal path, but I don't think that will make it any better than it is right now.
The Node's User interface is very intuitive and allows you to tag playlists from your streaming service as well as select anything you would like from your streaming service. Takes a little getting used to but is very fast and well organized.
Now to the sound quality... I have listened to many of my favorite redbook CD's and their compliments from Bluesound/Tidal and can hear literally no difference. Now that's not to say you won't hear any subtleties with your ears but when I go from CD to Bluesound I can't tell any difference except the Bluesound has a bit more gain.
Net result is that you are looking for a streaming player that is technically solid, looks and sounds great and don't want to spend half of your listening time fiddling with the settings and integrating and patching the interface this is a very strong player.
YMMV
My 2nd issue was I repacked the unit with all original packing and boxes but when I got home it had come apart like a clam shell. The thin plastic around the screws gave way. I am very meticulous packing and unpacking gear as I have traveled with 10's of thousands dollars in gear for these shows without a single scratch or mishap.
So now the unit has been put away. It still works but the adding songs to playlist issue wasn't going to fly.
https://support.bluesound.com/hc/communities/public/questions/203270828-Playlist-management?locale=en-us
https://support.bluesound.com/hc/en-us/articles/206794887-How-Do-I-Add-a-Track-to-a-Saved-Playlist
The software is easy to install and use. I never ran into the adding song to playlist issue I guess mainly b/c I play albums, or I add albums to playlists. even when i "Group" the players (Node and Node2) I see no delays or lags. My network and router are very fast so i would expect 0 performance problems
I have used the BS app on my android phone and tablets and it works fine.
How do you navigate the folders on a hardrive connected via USB? Through the app? Top display?
Does the top display more than just the play functions?
Does it have spotify in bedded so that i just change the song with my phone or am i streaming to the device via bluetooth?
Is it just the two inputs, USB and Optical?
Thanks!
My Sonos does, I can create playlists between all media, mix and match between music services and personal cd's. I see no reason why the BS wouldn't, but I'd check with users first.
that unit looks interesting. Can it send dsd to the dac? Can the usb port just have like a 2 gig drive on it?
Living Room:,T+A PA 1530R,Wireworld Silver Eclipse SC, Tyler Highland H2, High Fidelity Reveal RCA, Innuos Zen MK3 , W4S recovery, LKS MH-da004,
Have but haven't used in a while: LH Labs VI Dac, Cayin SCD50T, Grant Fidelity Tube Dac11,Aries Mini
Yeah, i have the paid version but i dont want to stream via bluetooth. I was hoping the software was embedded so that there could be a hard connection. My laptop is currently sitting in this role.
I can only deduce that since the old BS Node didn't have Blutooth that the Spotify app was embedded but i will research on the their forum.
I haven't used Itunes in many years now and can only assume that it is better than when I threw my Iphone against the wall after Itunes lost all my S**t for the 3rd time.
This really looks like a great unit and reasonable on cost!
Basically, yes. Your not going to find these all in one devices cheap that will do it though. Like I said, dedicated higher end music servers do it, but it will cost some. If you just want cd quality, Sonos is hard to beat mainly because they have the best software out there and ease of use. BS kicks it up a notch with being able to play higher rez formats, but I'm not sure how well their software integrates as I've never played around with one. That's where Mikey comes in.
You might be able to find a few used MS'ers from the likes of Teac or Sony that can stream DSD for roughly 5-800 used. Cambridge too I think has something in their line-up as well.....a few others also.
