position for one set of Vibrapads
I got 2 sets of 4 Vibrapads from Afterburnt (Bruce) and positioned them under my JVC-tt. I have 1 set of 4 left, and judging from what you can see, or what is the next most important device that I should use this last set for ? I do have cork pads but these things are thick and very hard. So far my tt leveled and I did not really notice any change either way but I did not open them up because it was way to early.4ysukls6ini8.jpg
    Try the others under the cdp or pre. BTW....whats with the peek-a-boo covered gear in that 2nd pic ?
  • hochpt21
    hochpt21 Posts: 5,423
    I would double up under the TT.
  • hochpt21
  • hochpt21
    If you can zoom in, you can see I'm tripled. And there's one under the whole rack :)
  • Tony, summer sun streams right in on them about from 4 to 6 pm. Some preventative action while I was away for the weekend. I can't double up on the tt ,the cover will not open all the way and either would slam shut if I forgot to lower it or would be just a gross hassle w/ less clearance. Now, possibly I can maneuver by ditching the Blu/Ray to another shelf which would make the Denon cdp the next device to be raised.
    edited September 2015
    Tony, summer sun streams right in on them about from 4 to 6 pm..
    We have these new fangled things in the 21st century LW, it's called curtains. lol
    Maybe 4-6 pm is when you walk around naked in front of the window ?? :)
    Try the gadgets under any piece and see where you notice any differences. Usually light weight pieces, or anything that the feet look sub par on.
  • steveinaz
    steveinaz Posts: 19,546
    I found vibrapods to work real well on transports, or any piece with moving parts.
