Sda Cables
trubluluc
trubluluc Posts: 2,067
edited September 2004 in Vintage Speakers
Is it true that these special interconnect cables are not available, for most models, through POLK?
-Luc
Post edited by trubluluc on
    F1nut Posts: 51,700
    True, the pin blade type is not. You can make one though.
  • trubluluc
    F1nut-
    Is there a diagram or layout that describes the process of building your own?
    -Luc
    F1nut Posts: 51,700
    Not that I'm aware of. It's easy to make though, start with a good quality speaker wire or 2 wire electric cord, then terminate the ends with one spade and one round pin, making sure they fit the hole and slot on the speakers. Add some shrink wrap and you're done. It's said that you don't really need one of the connections (I don't remember which one), but since there are wires connected to both on the inside, I'd do them both.
  • rskarvan
    rskarvan Posts: 2,374
    Each speaker feeds the other part of its signal. Hence, two wires.
    REGARDING:
  • TroyD
    TroyD Posts: 13,124
    Here is what Ken had to say about it...
    Hello Troy,
    The bade and the pin are both connected to the same wire in the original SDA pin/blade cable. This was done to prevent owners from damaging their non-common ground amplifiers. All that would happen would be that there wouldn't be any SDA corrective signal present, but the amplifier wouldn't be shorted out. If the amplifier was a common-ground design it would provide the necessary left/right grounding and the SDA would be heard. So, the pin does one of the connections and the amplifier provided the second. When building a pin/blade cable there's no need to connect the blade, since the amplifier will provide the connection. The only plans I have are for building a non-common ground SA-1A cable with isolation transformer.
    Regards, Ken, Polk
    BDT
  • HBombToo
    HBombToo Posts: 5,256
    Hello Troy,
    Regards, Ken, Polk
    BDT
    Thanks Troy.
    Are there any diagrams anywhere with regard to the isolation tranformer configuration?
    HBomb
    ***WAREMTAE***
  • trubluluc
    F1nut Posts: 51,700
    What's the make and model? Almost all receivers are and most amps are except dual mono's, bridged amps and mono blocks, of course.
  • trubluluc
    F1nut-
    Yeah I have Yamaha receivers newish...so probably are.
    -Luc
  • madmax
    madmax Posts: 12,434
    Am I missing something here? If that were correct then the transformer in the isolation cable could not work. Did they not sell the isolation cable for the pin-blade versions? Actually, isn't the pin-blade version the only one that works with the isolation transformer??
    madmax
    Vinyl, the final frontier...
    F1nut Posts: 51,700
    With the isolation transformer in use you have to use a two wire cable.
  • HBombToo
    Originally posted by trubluluc
    -Luc
    disconnect the power amp from the outlet, remove all connections and get your VOM. Across the speaker terminals place the leads to the VOM across the black and red speaker teminals and it will show 0 Ohms if it is a common ground amp.
    My outlaw is not common ground unfortunatly.
    HBomb
    ***WAREMTAE***
  • trubluluc
