Using 7's as stands for CRS's?
Is this OK as a temporary solution while I wait for proper stands? It just occurred to me that the 7's are just about the right height, and the caution people would exercise around the set-up might help protect the CRSs which for now are way too low on my OEM 7 stands.
I'd isolate with solid rubber feet, and do not plan on a true 'stack' in that I won't run all 4 at once. The 7's would actually serve as non functioning stands.
Any issues to watch out for? Thank you for the help!
    Toolfan66 Posts: 18,048
    No issues good fix till you get better stands... Enjoy!!
  • I also temp changed my set up. My M7s were on iron slant stands originally made for JBL-2060s and while M5s might fit these 7s were a little to tipsy. So 52x6xozic4i7.jpg
    untill I get some nice wood stands that Mark Hardy and some others have right now they are on top of my ADC 303ax and again not so much into stacking but I had to get them out of the way.Those stands are now used for my EPI v100s and are a perfect fit
