Mac Mini to DAC Questions
I'm new to the music server/DAC side of this hobby and need some help. I was researching the use of a Mac Mini (I can get one relatively cheap) as a music server with its output going to a DAC then from there to a pre-amp. From what I can find the outputs of the Mini include USB type A, HDMI, Thunderbolt, Headphones and some Mini's have Firewire. While the inputs of most DAC's seem to include; USB type B, coaxial digital & optical. Question: Is it as simple as a USB type A to a USB type B cable? Or is something lost from the conversion from A to B? Are there other options for a connection from the Mini to a DAC? Thanks for any help, Don
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
  • mikeyb128
    mikeyb128 Posts: 2,885
    I use a dh labs silver sonic from MacBook Pro to my benchmark dac (I got it cheap). My next upgrade will definitely be a wire world cable. They look really nice. Oh I use a to b. From my research the best audio is through the usb.
    2 channel:
    Theater:
  • stogie
    stogie Posts: 230
    Thanks for the recommendations- I'll look into those cables mentioned.
    TT: Technics SL-MA1
