Looking for a High quality CD Player?
hamzahsh
If I've to choose between
NAD C542 or
Cambridge Audio Azur 640C
Which one should I go for, I'm looking for a high quality sound. My budget is $700 Canadian Dollars.
OR is there any other brand you can recommend.
NAD C542 or
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
NAD C272 (2-ch Amp)
Post edited by hamzahsh on
I'd get the NAD between those two. I really like my "lowly" NAD C521!
You might also want to check out the Arcam CD63 or a used Arcam CD73, both very good players. I've also read a lot of good things about the new Rotel RCD-1072.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
That is a win-win proposition. Both great players; i do admit a bias towards the Cambridge because I owned the D500SE, and it was a wonderful player. It seems the 640C is following in it's foot steps and then some.
If I were buying, it would be the Cambridge. The costruction is just a little bit better (I felt) on the Cambridge--which edged it out for me when I was also looking at the NAD.
As a note, the 640C uses the same DAC as the highly regarded Rega Planet 2000.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Hey Troy, isn't that the CD player we heard with the ProAc's?Bob Mayo, on the keyboards. Bob Mayo. -
Originally posted by Zero
Music Hall CD-25
Absolutely!, another giant killer at a good price. And the Ah! Njoe Toeb 4000 at $699.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I've not seen a Cambridge or a NAD..........I have been considering a Denon only to match existing componets. Feedback from the experienced is and will be interesting.
Good Luck !......................:DDenon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
Some great CD Players can be found in the $350-$700 range that will give $1000 and up players a serious run for their money. Here's a few:
1. NAD C-540 series
2. Cambridge Audio D500SE, Azur 640C
3. Rega Planet 2000 (used)
4. Ah! Njoe Toeb
5. Music Hall MMF-25
6. Sony ES series
7. Vintage 18-bit Yamaha "900" series (used)
...I'm sure there are more.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Also check out Rotel RCD 1072 for $699.00Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Thanks guys for the input, I'll look forward to both NAD C542 and CA Azur 640C CD player.
My another question is, how would I know if I'm using CD player's DACs or my A/V/Pre/Pro DACs. I heard that when you use Analog outputs you're using CD player's DACs but if you're using Optical or Coaxial output you're using A/V/Pre/Pro DACs. Which is better and why?
Tell me if I'm wrong.
NAD C272 (2-ch Amp)
Malata DVP-580 (Multi-region DVD player) -
C'MON Guys Answer my Question?
Who knows!
:mad:Panasonic TH-50PX80U Plasma HDTV
NAD C272 (2-ch Amp)
Who knows!
:mad:
Cambridge Audio.
Analog = CDP DAC
Digital = AVR/ Pre-Amp DAC
Analog vs Digital is completely your decision. It's a loaded question because it's 50/50 in general opinion. I prefer analog, and digital coaxial output for DTS only. I have no interest in optical and do not like the performance in my listening enviroment.
Good luck.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
This is correct...so the issue become which has the better DAC...or in reality which one sounds better to you. Good CDPs ususally have pretty good DACs...but so do good pre/pros.I heard that when you use Analog outputs you're using CD player's DACs but if you're using Optical or Coaxial output you're using A/V/Pre/Pro DACs."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Thanks guys!
NAD C272 (2-ch Amp)
yes sir!Originally posted by gmorris
Hey Troy, isn't that the CD player we heard with the ProAc's?Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
