Stupid is as stupid does
tonyb
tonyb Posts: 33,065
Yep, no matter how acclimated to audio you are, you still do stupid stuff.
Changing up some IC's for sh&ts and giggles the other day, turned everything off as normal....except the dac. Not on purpose, just simply forgot. Hook it all back up and **** if the dac turns on and shuts off right away.
I knew exactly what I had done....followed up by a slew of cuss words. Took the dac out, popped the top to see what I could see.....nothing. Everything looked clean, nothing fried. Put it back in.....same sh&t.
Now I am pissed off at myself. So I unplug it, take it out and let it sit all alone in the corner until I decide what to do with it. A few days goes by...and before I send it off to Cary I want to give it another shot. MF'er.....fires right up like nothing ever happened.....Tony breaks into his happy dance.
No matter how old ya get, how much you think you know about audio, sh$t happens to the best of us at any given moment. I got lucky this time....next time though, I'll probably burn the joint down. :)
  • Upstatemax
    Upstatemax Posts: 2,731
    Lol.
    In a rush one time, I hooked up my phono stage in reverse...
    I plugged the TT into the outputs and the Pre into the inputs. I spent 45 minutes testing the TT and cart before I had the genius idea to double check my connections to the phono stage.
    I was really mad at myself for about 20 seconds, then I just laughed at myself for a good long time.
  • oldrocker
    oldrocker Posts: 2,590
    I've done my fair share of "oops" that's for sure.
    The latest was our recent outdoor gathering we had which consisted of me hooking up a persons ipod to hear a song. What was unknown to me was that ipod was set to max on volume and what not.
    I then saw my 57 year old brother start to "cut a rug" in the back yard, which then I had to advance the volume dial on the receiver. After we laughed at his "dance" moves, I looked at the right speaker and this was the end result.
  • smglbrth
    smglbrth Posts: 1,495
    edited August 2015
    tonyb wrote: »
    That's sig material right there...
  • madmax
    madmax Posts: 12,434
    When upgrading tubes in my preamp I looked at the manual several times to make sure I was putting the correct ones in the correct place. It was so obvious where they went from the physical layout also. So I plug it in and CRACK! Looking closer I got two of them swapped and blew up a capacitor. To add insult to the whole mess I looked up swapping the tubes on the Manley website and it said things may blow up if the tubes are swapped. Worse yet it said something like "anyone can change their own tubes, unless of course they are too stupid to replace a light bulb on their own"...
    Vinyl, the final frontier...
  • Mikey081057
    Mikey081057 Posts: 7,127
    tonyb wrote: »
    The crazy part is that it started working again... I guess Cary makes self repairing circuits? Walt Duflock.... How can this be explained? Like it has a circuits that can go into shutdown and then bleed off?
    or
    They have elves that they send out to fix stuff so you don;t have to send it back to them.
    I would like to know how this now works after it didn't...
    Garage | Polk Monitor 5B's
  • BlueFox
    BlueFox Posts: 15,251
    Sometimes the gear needs to be unplugged for a bit before it resets. I sent a file player back to Bryston, and they returned it as no trouble found. When the problem occurred again (due to an external power issue) I was ready to send it back again, but right before I boxed it up I plugged it back in, and it worked. Ta-Da!!!!
  • nguyendot
    nguyendot Posts: 3,594
    Based on title of OP, came in expecting a PFB themed post. Disappointed.
    Main Surround -
    tonyb Posts: 33,065
    BlueFox wrote: »
    That's my guess....no Cary Fairy's showed up in the middle of the night. I was just lucky enough nothin' got fried as a result of my stupidity. The audio Gods were looking down on me with favor. Nice to know at least one does....lol.
  • scottyboy76
    scottyboy76 Posts: 2,905
    Not long after getting my dream speaks sda 1cs, I hooked something up wrong and fried 2 mids and one tweeter.
    Within 2 hours of venting on here I had guys standing in line with replacements, refusing money just wanting an addy to send them to, trust me there were tears.
    There have also been tears lately cause its the first time my bunghole has relaxed enough to go no. 2 since that happened.
    humpty dumpty was pushed
    pitdogg2 Posts: 26,925
    tonyb wrote: »
    No matter how old ya get, how much you think you know about audio, sh$t happens to the best of us at any given moment. I got lucky this time....next time though, I'll just burn a joint. :)
    fixed it better......
    Seriously I just basically did the same thing but I tried to blow up my amp. Switched cables forgot amp was on, so I turn off then proceed to pull out audio cabinet enough to allow one speaker cable to come unhooked took all but the last fuse before I figured it out....yep I didn't do the happy dance as I'm all out of fuses
  • Moose68Bash
    Moose68Bash Posts: 3,843
    @tonyb,
    Some of us -- namely me -- have done so many stupid things of this order that we such wouldn't know where to begin describing them.
    It's only when they occur rarely in your life that seem to so noteworthy!
    Glad the Cary survived, but it was probably sending you a message! :)
  • ukcolin99
    ukcolin99 Posts: 286
    You can barbecue it, boil it, broil it, bake it, saute it. Dey's uh, shrimp-kabobs, shrimp creole, shrimp gumbo. Pan fried, deep fried, stir-fried. There's pineapple shrimp, lemon shrimp, coconut shrimp, pepper shrimp, shrimp soup, shrimp stew, shrimp salad, shrimp and potatoes, shrimp burger, shrimp sandwich. That- that's about it.
  • vmaxer
    vmaxer Posts: 5,120
    You left out shrimp gumbo
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer wrote: »
    And shrimp & grits!!
    Paradigm 11seMkIII mains, w/ Zu Audio jumpers
    Paradigm CC 450 center, w/ Zu Audio jumpers
    Polk Audio RTi6 surrounds
    Paradigm SE sub
    Sony BDP S5100 blu-ray player
    Panasonic 50" plasma
    Yamaha RX A1000 receiver
    Parasound HCA 1205A amp
    Audioquest Evergreen IC's
  • Moose68Bash
    @tonyb,
    Some of us -- namely me -- have done so many stupid things of this order that we such just wouldn't know where to begin describing them.
    It's only when they occur rarely in your life that they seem to be so noteworthy!
    I really have to do a better job of proofreading my posts.
    I fixed the one above! :|
    edited August 2015
    Completely identify with the above. Here, I,ve typed thousand and thousands of pages in my life, and I'm still a s(h)itty typist! lol I also suspect that I may have some mild dyslexia because I sometimes don't see the mistakes and have to re-read some posts very very slowly (out loud in my mind), looking for the errors!
    Literate/illiteracy and Illiterate/literacy! My 17 year old daughter types faster and with fewer errors than I?
    tonyb Posts: 33,065
    Join the club CNH, the club of old farts trying to keep pace. Don't know about you, but in my day men didn't do typing. It was a task learned way too late in life while kids today are typing when they are 2.
  • BlueFox
    cnh wrote: »
    Exhibit A. :)
    Sometimes I do not see the error until a few hours later. By then Polk has shut down editing. Some other, more high-end audio sites allow longer editing times, such as 24 hours to infinity, and beyond.
    Where would I be if I didn't leave an example as proof? Lol
  • Moose68Bash
    Like BlueFox, often I don't see my typos till it's too late to correct them because my 60 minutes have run ought.
    These days, I think some of these typos are because of the autocorrect function -- at least that's what I like to tell myself :)
  • rooftop59
    rooftop59 Posts: 8,121
    over the summer I switched cable companies, and some cords in the main system were loosened a bit. I got most of them corrected, until I noticed that I only had one outdoor speaker working. Now on the one hand I don't have the excuse of, um, experience like some of yous guys, but I do have like 17 toddlers running around my house, where it is basically constant insanity. So I will make that my excuse. Anyway, I went inside and starting futzing around with the cable running to the outside, when all of the sudden everything shut down. NO, I had not turned the system off, and yes, I know better. Luckily all I lost was a mid level Denon reciever that I had only paid about $150 bucks for and gotten about a year of use out of, but still I was pissed. It was a great receiver that served my purposes perfectly. But if I had been a really expensive piece of equipment, man I would have been pissed! LIve and learn!!!
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,065
    17 toddlers ??
    You need your own reality TV show my man. :p
  • rooftop59
    tonyb wrote: »
    17 toddlers ??
    Well that's what it feels like sometimes...but as far as reality TV goes, just say no!!
    Game Room 5.1.4:
    Bedroom 2.1
  • Upstatemax
    edited August 2015
    wrong thread.
    Lol
  • gurot1
    gurot1 Posts: 519
    17 toddlers? How did you manage to fiddle around with the cables without someone deciding to help you and pull a cable or push a button without you knowing?
    lsim705,lsim706c,lsif/x(4)+mc80(atmos)
    rti6,csi5,fxi5
  • rooftop59
    Well okay not quite 17. But with 4 kids and Twins in the mix it feels like that sometimes. I went to in ceiling speaks in the living room a long time ago cause I figure the fight wasn't worth it...
    Game Room 5.1.4:
    Bedroom 2.1
