Going Sealed..
  • ken brydson
    ken brydson Posts: 9,011
    Odd that you're having problems posting pics. That to me was one of the very few improvements vanilla brought to the table...
  • felipe
    felipe Posts: 423
    I found it odd to...unless I'm doing it wrong. I tried using the "attach file" icon where you leave the comment..didnt work for me. Is there another way? I'm using an IPad..
    My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
  • rooftop59
    rooftop59 Posts: 8,120
    When you push the attach file button, it should pull up the option to either use existing photos or take a new photo (it basically works the same as when you try to text a pic). I think that's the only way to do it on an iPad but I could be wrong...
    Game Room 5.1.4:
    Bedroom 2.1
  • mikeyb128
    mikeyb128 Posts: 2,885
    rooftop59 wrote: »
    I do this for iPhone and works flawlessly.
    2 channel:
    Theater:
  • felipe
    felipe Posts: 423
    Alright guys, I'm not having any luck here :(. Whenever I click,tap or push on the attach file icon ( icon looks like a sheet of paper with the right corner folded ) nothing happens..? Actually, I tried the other icons as well thinking maybe its just that particular icon, but NONE of them pull up any options of any kind..nothing happens. ??
  • vmaxer
    vmaxer Posts: 5,120
    edited August 2015
    Then click on choose file....see screen shot below.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • felipe
    felipe Posts: 423
    Hi vmaxer. Thanks for the screen shot. Unfortunately, that prompt doesn't even pop up when I click on the icon...nothing happens at all. I don't get it...
  • rpf65
    rpf65 Posts: 2,127
    I think he means the folded page prompt, just above the "leave a comment" box.
