FS: Anthem Statement P2 Amplifier
bdaley6509
In excellent shape. Pickup preferred near Charlotte, NC, but will ship if buyer pays all costs to have it packed properly by the UPS store (I do not have original box). $1499.
[url="[URL=http://s299.photobucket.com/user/solid187/media/IMG_3190_zpstmbg3trc.jpg.html][IMG]http://i299.photobucket.com/albums/mm315/solid187/IMG_3190_zpstmbg3trc.jpg[/IMG][/URL]"][/url]
Specs:
General
Inputs 2 Single-Ended, 2 Balanced, 1 Relay Trigger (3.5 mm Mono Jack)
Outputs 2 Pairs Speaker Binding Posts, 1 Relay Trigger (3.5 mm Mono Jack)
THD+N (225 W into 8 Ω) 0.0007% at 1 kHz, 0.008% at 20 kHz
IMD 0.00019% (CCIF, 325 W into 8 Ω)
POWER BANDWIDTH 10 Hz to 150 kHz
(+0 -3 dB, 325 W into 8 Ω)
FREQUENCY RESPONSE 20 Hz to 20 kHz (+0 -0.15 dB),
5 Hz to 100 kHz (+0 -2 dB)
INPUT SENSITIVITY (RCA and XLR 0 dB inputs) 1 Vrms in for 28.3 Vrms out
(100 W into 8 Ω)
INPUT IMPEDANCE 18 kΩ (RCA), 22 kΩ (XLR)
DAMPING FACTOR >600 at 20 Hz, 400 at 1 kHz (ref. 8 Ω)
S/N RATIO 125 dB, A-weighted (ref. 325 W)
CROSSTALK (between any two channels) -140 dB (20 Hz), -80 dB (20 kHz)
VOLTAGE GAIN 29 dB
SLEW RATE 40 V/µs
SWITCHES
Front Panel Power (On/Off)
Rear Panel On/Off Modes (Trigger, Manual, Auto), Inputs (RCA, XLR, XLR -6dB)
POWER OUTPUT
(Per channel, continuous RMS, 20 Hz to 20 kHz, <0.1% THD, one or all channels driven.)
Impedance 8Ω 4Ω 2Ω
# of Channels Driven 1 All 1 All 1 All
325 W 325 W 500 W 500 W 675 W 675 W
Statement P2 and P5 amplifiers are stable into any impedance down to a short circuit at full output.
POWER REQUIREMENTS
SUPPLY VOLTAGE 105 to 130 V, 60 Hz
POWER CONSUMPTION 1800 W
DIMENSIONS
Height 9-3/8 inches (23.8 cm) including feet
Width Faceplate 19-1/4 inches (49 cm)
Chassis 17-1/4 inches (43.8 cm)
Depth 22-1/2 inches (57.2 cm) including handles
Weight (unpacked) 75 lb (34 kg)
Specs:
General
(100 W into 8 Ω)
VOLTAGE GAIN 29 dB
SLEW RATE 40 V/µs
SWITCHES
POWER OUTPUT
Impedance 8Ω 4Ω 2Ω
POWER REQUIREMENTS
DIMENSIONS
sold.
