Removing "ink" residue from vinyl wrap.
soundfreak1
soundfreak1 Posts: 3,414
edited August 2015 in Vintage Speakers
Have a small faded but visable residue of ink (looks like like black marker) on vinyl rap on face od turntable wood. Any suggustion on safe removal.have tried glass plus , ammonia but no results. (See pict)mohhjjfg93q2.jpg
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
  • ken brydson
    ken brydson Posts: 9,002
    Goof Off or Goo Gone will probably work.
    pitdogg2 Posts: 27,048
    i thought the same didn't know if it would remove the finish
  • soundfreak1
    Thats my concern (the finish) if wood some watkins and some 0000 steel wool would do it but on the vinly rap no way.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • aprazer402
    aprazer402 Posts: 3,386
    edited August 2015
    Do not use Goof Off, it is strong nasty stuff, it will most likely damage the vinyl. Goo Gone is weaker, I would try it if you have some on the bottom or an out of sight place first. I would try 91% rubbing alcohol, from a drugstore, on a cotton ball first.
  • soundfreak1
    I tried everything and found the answer and you wont believe it!!!! Found idea on web IT'S MAJIC ERASER! Used dry on ink on the vinyl rap and it gone took it right off with no effort at all.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    txcoastal1 Posts: 13,513
    LOL now go clean the stylus
    msg Posts: 10,452
    edited August 2015
    no way... cool!
    I still don't understand how those things work.
  • soundfreak1
    It's "MAGIC" LOL but it worked like a charm!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
