Jewels, how many do you need?
  • mikeyb128
    mikeyb128 Posts: 2,885
    As many jewels as I can fit Into my house in a lifetime.
    2 channel:
    Theater:
    mhardy6647 Posts: 34,955
    we talkin' family jewels, Swiss watch movement jewels, engagement ring/bling jewels, or what?
  • vcwatkins
    vcwatkins Posts: 1,993
    Just two, thanks.
    edited August 2015
    Trauffaut? Jules and Jim?
    Jools Holland?
    ... or maybe even the SI derived unit of energy , which, in terms of fundamental SI units, is 1 kg-m^2 / sec^2 ?
    SCompRacer Posts: 9,091
    https://youtu.be/mjCRUvX2D0E
    How many gigawatts in 1 joules per hour? The answer is 2.77777777778E-13.
  • afterburnt
    afterburnt Posts: 7,892
    Seriously is one better than the other?
  • mikeyb128
    I've got a Panamax m5400 pm in the mix. It's been pretty nice. Matches the marantz perfectly. I've had several other Panamax products with zero issues. But whole house surge protection at the fuse panel is better than anything at the wall plug. And cheaper too.
    2 channel:
    Theater:
  • ken brydson
    ken brydson Posts: 8,996
    You only need 2. Any more is just bragging ..
    tonyb Posts: 33,069
    afterburnt wrote: »
    A more direct answer is....not that I can see, no.
  • Upstatemax
    Upstatemax Posts: 2,735
    I have had two of those APC's, one is still in my 2ch rig. IIRC, a fellow Polkie bought the other H15 off of me.
    The H15 has been great, zero issues.
    The major advantage that the H15 will have over the Panamax is true voltage regulation. The Panamax will simply shut down if voltage gets out of hand (too high, too low).
  • Willow
    Willow Posts: 11,228
    To make a decision; two
    To have a child; one
    To sing soprano; none
  • leftwinger57
    leftwinger57 Posts: 2,917
    You guys were brutal w/ this dude ..lol But for his benefit I'll tell him no matter how many joules your conditioner , power center or plug strip has nothing is going to help against a direct or even a near miss lightening strike. My Sampson PS-15 I think has some 1200 joule protection which I know is not a lot but it has the requisite number of outlets which is 9 and conditions nothing. Also has a giant lit rocker switch and a small reset switch.
    http://www.avshop.ca/sound-amp-pa-audio/power-distribution/samson-powerstrip-ps15-power-distributor
