Can I use a TL3 (or other) Center Channel for My Monitor 70's?
My local guy only has the CSiA4, a TL3 and a TSx 150c. for center channel speakers from Polk. I know the ideal center channel is the CS2 but I am hoping one of these would be just as sufficient and would sound as good as the CS2 model with my Monitor 70 speakers.
Thanks!
    tonyb Posts: 33,067
    DSkip wrote: »
    Skip them all and find a used cs20.
    Agreed.....while the a4 is a nice center too, it won't be timber matched the M70's.
  • I read that the CS10 and CS20 have a different tweeter than the CS1 and CS2. Is the difference to minimal to care about? My local dealer does not have any of these and I prefer to use him if I can. That said, if none of what he has is a match then none of it is a match.
    All he has is TSx250c, TSx150c, TL3, TL2, TL1, CSiA6, CSiA4. Sounds like none of those will work though. Thanks!
