DCM Time Window 1A or match Polk R50s or Monitor 70s
lendon
lendon Posts: 30
edited July 2015 in Speakers
Hello everyone. Looking for some input.
Right now I have a Yamaha RX-V475 receiver powering two Polk R50s for the fronts with some crappy KLH for rear and center channels.
First option I am thinking replacing the fronts for something better like a matched set with a matching center channel and putting the R50s for the rear channels.
My second option is two more R50s with matching center so I have 4 R50s and the matching center for a true matched set.
Option three is getting some DCM Time Window 1As for the rear speakers and keeping the R50s up front along with grabbing a matching Polk center. I am just worried the DCMs are better then the R50s and what can I match as a center to them for fronts moving the Polks to the rears.
Last option would be some Monitor 70s for the fronts with a matching center, not sure how much of an improvement the 70s are over the R50s though.
I would like to add that I do listen to music about 25% of the time, the other 75% I would be watching movies if that makes any difference. Price is $200 on any of the routes I decide to go picking up these items in excellent shape on CL.
Post edited by lendon on
  • leftwinger57
    leftwinger57 Posts: 2,917
    From my limited knowledge of DCM I would not use TW 1a as surround fronts. they are terrific 2 channel speakers. I own the lower series of Time Frame 350s and even those are impressive but most say the TF 600s are the sweet spot. If you have to have a surround try to get DCM Soundscapes and a center and rears you could fill in as you go. You would need a better avr w/ pre=outs if you went all the way. her's a listing that's been up for months now that might interest you.
    http://cnj.craigslist.org/ele/5098273453.html
  • lendon
    lendon Posts: 30
    Thanks leftwinger57 for the reply. I figured the DCMs might be for a 2 channel setup and I am sure they sound wonderful for music and better then my current R50s.
  • lendon
    lendon Posts: 30
    edited July 2015
    Just saw a pair of Time Frame 400s and another pair of 600s online for sale in my area, they look sweet.
    So go get them and tell us what you think.
    Personally, since you said 75% of this is for movies, I think the Monitor 70's is the better bet.
  • lendon
    lendon Posts: 30
    tonyb wrote: »
    I am tending to sway in that direction. As much as I want to try the speakers out because of the good things I heard about DCM speakers I just don't think they will be perfect for me and what I plan on doing with them. Those old DCMs from the hours of my researching online don't seem to be home theater speakers but more 2 channel set up speakers for music listening. Guess I will look at some Polks, found some R50s, Monitor 70 series 1 and 2, Monitor 50 and some RT series so far on CL.
  • Jimbo18
    Jimbo18 Posts: 2,351
    I have never owned them, but from what I have read on here, the Monitor 70's like more power than your Yamaha AVR will provide.
  • Jimbo18
    DSkip wrote: »
    Polk RT series for the win. RT55's or RT800's would be a big step up and not strain the amp.
    Agree, Skip. My AVR is a similar model to the OP's and it runs my RT800's alright for HT.
  • lendon
    lendon Posts: 30
    Okay so cross the Monitor 70s off. I have found a few pairs of R50s on CL. Just came across a pair of RTi70 speakers for $200, not sure if that is a good deal or not.
  • lendon
    lendon Posts: 30
    Appreciate the advice also. Thanks!
  • lendon
    lendon Posts: 30
    edited July 2015
    Came across this review where a guy said he is using this avr to power some Monitor 70 series 2 speakers. http://www.newegg.com/Product/SingleProductReview.aspx?ReviewID=4176789
    It's not an amp, it's a receiver. You'll be fine with M70'S.
  • leftwinger57
    Another thing about DCM either Time frames or Time windows if not recently re foamed or re socked your in for a sh&t load of work that you might not be up for. There are some more knowledgeable people over on AK who have taken apart both series and it's a night mare. 1st the socks can't be reused then there is some kind of hairy liner that's a real pain and then once you get to your speakers have fun. Thankfully both my 350s were re socked and re foamed and paid $160 for that reason. Buyer beware. They are 30 some odd years old and some really sound and look like it.
  • lendon
    lendon Posts: 30
    I found a pair of RTi70s and was wondering how they compared to R50s, searching the internet didn't bring up too much.
    Miles better than the R50.
  • lendon
    lendon Posts: 30
    Thanks Tony. Will try and grab those over the weekend then find the matching center channel and a decent sub.
  • lendon
    lendon Posts: 30
    They are no longer available, damn! I did come across some RT800s which I assume are older and not as good as the RTi70s but it does have a matching center and sub with it. R50s are probably better then the RT800s I am guessing.
  • lendon
    lendon Posts: 30
    The RT800s are better then the RTi70s? I thought the RTi series is better then the RT just like the RTiA is better then RTi? Now I am really confused, haha. I really appreciate the help and insight. Getting something today hopefully, I am itching for some better sound in surround!
  • lendon
    lendon Posts: 30
    I just ran across a set of Klipsch RF5 speakers, they look mint and just a little over my budget. I also am not sure if my avr can power them.
    txcoastal1 Posts: 13,519
    lendon wrote: »
    With no problems
  • Dabutcher
    Dabutcher Posts: 2,606
    M70 work great with a good Reciever . 90 watts or more per side. Newegg used to have them on sale all the time for 300 for two w FS. Great deal and a five year warranty. Polk referbs on eBay are another great option. Peace.
  • lendon
    lendon Posts: 30
    Thanks guys. I am in Phoenix. The RF5s the guy is firm at $250 for the pair, kind of torn here which way to go either Klipsch RF5s or I can get the Polk RT800 with match center and subwoofer for $200. With the RT800 set up I could be done as I can put the R50s for the rears and have 5.1 surround. If I go with the RF5 I have to shell out like $300 for the matching center and maybe get a sub too. Hmmm, any opinions?
  • lendon
    lendon Posts: 30
    Could I just use the R50s for the rears? That center is a better match then the 300.
  • lendon
    lendon Posts: 30
    Thanks for the advice DSkip. What is your opinion on the RF5s? They seem to be better then all the speakers I mentioned. If you had to rate the RF5, RTi70, RT800 and R50s then where would you place them? Also would a CS400i being okay instead of the CS400 with the RT speakers? Thanks again!
  • lendon
    lendon Posts: 30
    I don't know what model the sub is either with the RT800s, would it be worth picking up if cheaply? Going to get the RT800s in a few hours for $100.
  • lendon
    lendon Posts: 30
    edited August 2015
    I just got the RT800s and am going to hook them up later. I am working on the CS400i which I found for $40. Going to see how these three with the R50s as rear speakers sound first, might not need a sub right away with the 4 towers. I am thinking of the layout like this would work perfectly and my living room is already set up as such. I really appreciate the help and advice and will report back when I have it set up.
  • lendon
    lendon Posts: 30
    The one CS400 you sent me a link to has blue woofers and not grey, not sure what that means.
  • ken brydson
    ken brydson Posts: 9,016
    edited August 2015
    lendon wrote: »
    400 has grey, 400i has blue. Not a ton of difference IMO. I wouldn't worry about it. Enjoy!
  • lendon
    lendon Posts: 30
    lendon wrote: »
    So this one in the link is a CS400i? https://phoenix.craigslist.org/wvl/ele/5110415489.html
  • ken brydson
    lendon wrote: »
    lendon wrote: »
    Yup. Screamin' deal too.
  • lendon
    lendon Posts: 30
    Well I found one for $40 and another for $50 on the CS400i. I have the RT800s hooked up right now as a 2 channel setup and they sound very nice, the clarity is notches above the R50s. Going to setup the R50s in the rear today and try and obtain the CS400i tomorrow. :smiley:
