ZU Audio Omen Stereo Speakers
Irrenhaus
Irrenhaus Posts: 1,105
Hi all
Will any of my two amps be able to drive this 12ohm speakers.
Adcom 585
Parasound 2125
http://sfbay.craigslist.org/nby/ele/5136086143.html
I think the price is great.
Rey
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
    EndersShadow Posts: 17,715
    edited July 2015
    @B Run had a set of these, hopefully he can chime in
    mhardy6647 Posts: 35,171
    edited July 2015
    Almost any amplifier should be thrilled to drive a 12-ohm load. More voltage, less current compared to low impedance.
    The Devil's always in the details, though -- what does the impedance curve as a function of frequency look like? Are there significant capacitive or inductive reactance?
    EDIT: Well... Google turned up this :-P
    http://www.audio-ideas.com/reviews/loudspeakers/zu-omen-loudspeaker.html
    Our impedance numbers closely parallel Zu’s, too, ranging between 10 and 20 ohms, with a matching phase curve with smooth values that indicate good coherence through mid and treble ranges. As an audio old-timer, I will note that a good old Baxandall slope tone control with an axis around 800-1000 Hz could turn this speaker into a very flat reproducer, because of its evenness of response above and below. If there were ever an argument for such a tone control, the Zu Audio Omen Standard is it in spades.
  • Irrenhaus
    Thanks for the info.
  • B Run
    B Run Posts: 1,888
    You can dive those Omen's with almost anything! They're a very easy load and very sensitive speaker. I used a Rotel receiver, Nad 326bee and ended up on a Peachtree iNova. I loved the way they pair nicely with the Peachtree, but they're supposed to really shine on S.E.T amps and i've also heard people have run them off T-amps no problem. They'd sound best with the Parasound out of the two choices, the warmer sounding amps can really provide excellent synergy.
  • Irrenhaus
    Thanks for the info. Just waiting on the seller to reply.
  • Irrenhaus
    No luck they are gone......too bad.
  • mrbiron
    mrbiron Posts: 5,721
    i'm running mine with a ps audio sprout just for kicks.....for now.
    No problemos.
  • I have been running both the Omen Def and Druid V with couple of tube amps during winter (Response Audio modified 3025 and 2a3 SET amp) and during summer I use Onix and/or TI 3116/3118 amps. As mentioned they work with just about any amp.
