Best used Amp can be purchased for < $500, to run SDA-2a's
2
    tonyb Posts: 33,067
    JNinja wrote: »
    GlennDog wrote: »
    I'm late to the party, but this is in your price range. NO Afil
    http://detroit.craigslist.org/wyn/ele/5129009579.html
    Not enough power
    For SDA 2's.....sure it is.
    msg Posts: 10,452
    and it's a great price.
    EndersShadow Posts: 17,687
    JNinja wrote: »
    @JNinja
    Where are you located?
    Albany, NY
    Darn too far :smile:
  • motorhead43026
    motorhead43026 Posts: 4,007
    edited July 2015
    I just bought a brand new A23 with no doubts it will drive my 2B's.
    There is also a brand new P5 in the future.
    – Kevin Alfred Strom
  • Nightfall
    Nightfall Posts: 10,084
    JNinja wrote: »
    GlennDog wrote: »
    Not enough power
    I'd take that Parasound over a pro amp any day, even if I had 2.3 or 1.2's.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • JNinja
    JNinja Posts: 100
    tonyb wrote: »
    JNinja wrote: »
    GlennDog wrote: »
    Not enough power
    Other than calling one "pro" and the other being a Parasound, can you explain why? Like on paper. Again, I'm willing to accept that I might like a less powerful amp more (more would be the only reason to 'upgrade' of course), but can anyone show me on paper how or why? How 225w will drive better than the 400w I have. I'm confident it may sound more wonderful in the low to mid volume (the way in imagining), but how does 225w>400w ... I'm not being sarcastic, I really want to know so I can make a good decision. Thanks
    txcoastal1 Posts: 13,500
    A lot of AVR's don't put out the line voltage needed for pro amps
  • JNinja
    JNinja Posts: 100
    So it may be beneficial for me to drop my AVR Marantz SR7300 in favor of a pre-amp 2ch correct?
    F1nut Posts: 51,689
    Current instead of voltage.
    Yes, but not for the input sensitivity issue as that's not going to change with a 2 channel pre amp.
  • JNinja
    JNinja Posts: 100
    Regarding inc the current, can I compare the two then? What might the current be with the Ashly amp vs the Parasound 23?
  • ambiophonics
    ambiophonics Posts: 727
    As I mentioned previously your pro amp takes a +4db signal to achieve full output and your home gear is running at -10db. I feel many of the amps suggested would provide plenty of power for you. I use a Carver tfm-35 with my sda-2btl and a passive preamp and can easily get to uncomfortable volume levels.
    txcoastal1 wrote: »
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • JNinja
    JNinja Posts: 100
    Got ya. Ok, I'm going to look into changing to a 2ch pre-amp, and at Parasound amp
  • JNinja
    JNinja Posts: 100
    Or what about: Parasound HCA-1500A http://www.ebay.com/itm/Parasound-HCA-1500A-205-WPC-Stereo-Amp-in-New-Condition-/281751358534?
    For $550 or less- is it a good deal? Good to run with my speakers to enhance over what I have now?
  • JNinja
    JNinja Posts: 100
    Alright guys, I went ahead and made an order...
    Parasound HCA 1200ii - $400 shipped
    Hopefully arrives in a week, and I'll be more than happy to share my experience regarding sound output, vs my current Ashly FET ... If it's as good as everyone says here, I'll sell the Ashly.
  • vmaxer
    vmaxer Posts: 5,120
    JNinja wrote: »
    Look forward to hearing your thoughts on this.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Polkie2009
    Polkie2009 Posts: 3,834
    Welcome to the 1200ii club JNinja, you're going to love this amp!
  • JNinja
    JNinja Posts: 100
    What is the going price? Was $400 good, bad, or right....I know it can't be too far off..just curious
    Yeah, I have always been in some kind of audio hole. My first car stereo consisted of about 2500wRMs and $7k
  • Polkie2009
    You did fine at $400.00 shipped. ;)
  • JNinja
    JNinja Posts: 100
    I'm glad I only paid $190 for the Ashly FET, if in fact I like this amp better...becaus the going rate on the Ashly is about $200, and it's crazy heavy for shipping...about 60lbs
    JNinja wrote: »
    You can probably use it for a passive subwoofer
  • Polkie2009
    The 1200ii is pretty heavy too, it's no slouch. Hopefully the seller will double box it for you. :)
  • JNinja
    JNinja Posts: 100
    How do you think that would mesh with SDA-2a's? A subwoofer added that is..
  • JNinja
    JNinja Posts: 100
    I have a 12" Sony powered sub from like 15 years ago. Only 150w rms but it puts out. Obviously this has nothing to do with the Ashly amp, as the Sony's powered...but I've thought about hooking up, but have not even tried. To be honest, low end doesn't seem lacking in the SDAs
  • Nightfall
    It's personal preference. The bigger vintage Polks have plenty of bass IMO.
    afterburnt wrote: »
  • vcwatkins
    vcwatkins Posts: 1,993
    edited July 2015
    You're gonna LOVE that Parasound with the SDA-2's. I'd say you're set for a good while. And as Tex said, you can save the Ashly for a future sub build (or even a couple of those Buttkicker things if you want more HT rumble). I'd avoid the Sony sub in any case.
  • JNinja
    JNinja Posts: 100
    Thank you all for the input, and help along the way.
    @JNinja
    Congrats! Thats a good price shipped as mine at 350 would have cost around 50 to ship to you as well.
    You will love it.
  • JNinja
    JNinja Posts: 100
    I installed the .5ohm resistor today, and it seems like everything's come together now..
    Recap of Polk SDA-2a system:
    -Receiver (still) : Marantz SR7300
    -Amp : (now) : Parasound HCA 1200 ii
    -Tweeters : (now) : RDO194's
    -Crossovers : (now) : Sonicap 12's Daytona 20's
    -Polyswitch : (now) .5 ohm Mills
    -Wires (now) : monoprice 12ga
    I'm about $700 in all togther, and countless hours invested in learning, reading (redundant) , and laboring...
    Overall, it's been a great experience and change, and it sounds VERY GOOD. It's difficult to put a number on sound, but I feel as if I have a $3k-$4k system all in all, and it feels good.
    I really do feel that ANY upgrade from here, would be negligible to my ears, or more for aesthetics/mental.
    Thanks for the help to those who did or tried.. As Borat would say: "SUCCESS!"
    F1nut Posts: 51,689
    Don't sell yourself short.
