Tube Buffers!!! Anyone using them here?
Well its always been 'to use or not to use' when it comes to the use of tubes. I got this lil grant fidelity buffer for $107 on agon last week and just thought why not hook it up today. I always thought the Krell 550 was a bit on the bright side and never wanted to invest or commit to a tube dac. Well problem solved! I have been running this between the perfectwave directstream dac and krell 550 and what diff. I like listening to tindersticks when my wifes mad at me as it helps me feel sorry for myself lol so I am intimately familiar with the songs and playing it now has earned me a new respect for the Krell.
Now I am wondering who has tamed a beastly musical component with one of these? I am running it stock so now I think, how bout some black bottle treasures or should I open it up and replace the caps inside to take it up a notch. If you have an integrated and want a lil something diff I really recommend getting one to play around with!
    gudnoyez Posts: 8,161
    I have read so many pros and cons on using tube buffers, some say only if you have a bias issue between your amp and preamp, others saying pretty much what you have just explained hoping to try one of the ifi one's that skips gonna send out for people to try out to see if I notice any differences with one hooked up.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    There is an instant diff right away for sure. If you have the spare ic's laying around then its something you should try.
    With the grant fidelity 283 mk2 buffer the volume seems louder and it has a sound thats more akin to a class A amp. I noticed the highs are taken down a tad butin a good way as far as the sound from the krell goes.
  • PSOVLSK
    PSOVLSK Posts: 5,381
    I had that same tube buffer. Excellent unit for the price and I second your recommendation to get one to play around with. It's actually one piece I really regret selling.
    So do you guys think trying a tube buffer out for one's first intro in to tubes is worth a shot or should one go straight to a tube preamp for that first try?
  • Polkie2009
    Polkie2009 Posts: 3,834
    Great post PFB, this is the unit that grabbed my attention a couple of months ago to try a tube unit in the mix without spending more than about $250.00 . Needless to say, having read many reviews on this unit and a few others ,I'm still keeping an open mind and will eventually end up with a tube buffer or tube preamp soon.
    Polkie2009 wrote: »
    That's got my curiosity I also want to try a tube unit in the mix be it a decent buffer or a preamp.
    DSkip wrote: »
    I think the iFi will be a great piece for you to try since it only costs you shipping to try it. I thought you were done going down that rabbit hole anyways...
    The trip down the rabbit hole will officially end after I have experienced some kind of tubes in the mix. I hope it will end, does it ever really end?
  • voltz
    voltz Posts: 5,384
    You know my Vincent Preamp & amplifier are Hybrid's. My preamp has 2 tubes in the input stage and 2 in the output stage & my amp only has 2 in the input stage.
    I always wondered if it wasn't just like having a tube buffer built in and maybe that is why I like them so much.
    I'd give Skip's iFi a try and give up any thought of being out of the rabbit's hole!
  • Jetmaker737
    Jetmaker737 Posts: 1,118
    gudnoyez wrote: »
    Yes, definitely. It was a Yaqin tube buffer that got me into tubes. Was an inexpensive and fun way to try them. Like PFB I could hear the diff immediately and liked it.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    DSkip wrote: »
    Heard great things about the iFi piece too.
    A tube pre is really more than just a tube buffer. But I do believe that a good tube buffer will or should give one a little more warmth-there is, of course, the synergy thing to consider as well. I'm pretty sure I would agree with PFB's take above if I heard his system.
  • Stew
    Stew Posts: 645
    A Yaqin tube buffer was my gateway drug. Followed by a tube CD player and tube pre.
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
  • OleBoot
    OleBoot Posts: 3,135
    Somewhere in my "put it in here and immediately forget about it" room, I think I have a Musical Fidelity X10-D from the mid 90's. I'll take a look. Maybe there's also a pair of 1957 Quad IIs I forgot about as well. B)
  • dhart86
    dhart86 Posts: 1,594
    Stew wrote: »
    A Yaqin tube buffer was my gateway drug. Followed by a tube pre.
    That was how it happened for me also
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • pearsall001
    pearsall001 Posts: 5,293
    DSkip wrote: »
    Everything you have heard about the iFi tube buffer is spot on...I can personally attest to that.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    A tube buffer is really a cathode follower stage, which most classic preamps (Audio Research SP3a for example, or Marantz 7C) have built in. It offers the previous stage a high input impedance and outputs a low impedance with unity gain.
  • erniejade
    erniejade Posts: 6,321
    I have been running a Yaqin I picked up from Pitdog2 after my W4S dac2 for a while now. It gives it some soul!
  • erniejade
    I also forgot to say, when I ran a McIntosh 6900, I ran it between the pre out and amp in with fantastic results.
    pitdogg2 Posts: 27,048
    erniejade wrote: »
    Which allowed me to upgrade to the yaqin cd3 that uses 6sn7 tubes....love it for sure.
  • boston1450
    boston1450 Posts: 7,758
    I run Yaqin cd1 & cd2 (thanks to members here) with great results. I roll different tubes ive got for different people here/online & enjoy them. Couldnt be more happier for the coin
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    erniejade wrote: »
    . IIRC i got some Voskhods from you ?? I roll them with the Mullards i got from Mike & i tend to stay with those sets on the cd2. Love them. Big thanks to Mike as he set me up nicely with cd2 & ALOT of extra's & info & walked me through everything a couple years ago & he also ripped some vinly-2-cd's :smile: since then im now enjoying my tube amp & tube cd player & rolling tubes in it. Only bad part is i want better now.
    Sorry to derail. Carry on
    Randy-Maine
    by David WMG
    Yep correct there great tubes IMO.
  • Msabot1
    Msabot1 Posts: 2,098
    Exactly....
    Ken meaning? Will one make a difference in preamps that dont to some extent?
  • I started playing with tubes via a Grant Fidelity tube buffer. I lmmediately loved what it added. Stepped up through a series of better tubes, and the improvement was instantly noticeable each time.
    Sometimes I would settle down to listen and thought my system sounded flat. Each time I noticed that I had left the tube buffer turned off. Switching it on, the magic returned.
    That convinced me to buy a series of tube preamps and tube integrated amps. Sold the Grant Fidelity tube buffer, but probably should have kept it.
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
  • [Deleted User]
    "Ken meaning? Will one make a difference in preamps that don't to some extent?"
    That's a good question and I'm not sure there's an easy answer. What one might be doing is allowing two components (a preamp and a power amp, or a CD player and a preamp) to communicate better. If you look at the classic Audio Research SP3a the phono section has a cathode follower stage after the two tube gain stages. Then the line level section has a cathode follower after the two tube gain stages. So when playing a record there's two cathode followers involved in the final sound.
    With all the confirming opinions, on CP, about the sound quality they can provide it seems to indicate their sonic benefits outweigh the addition of extra parts/circuitry in the signal paths. If you look at the Dynaco PAS3X it doesn't have a cathode follower circuit in the phono stage and it doesn't sound as good as the SP3a, in my opinion. I'm sure there's other things that contribute to that, but it is interesting.
    I would recommend trying one and see.
  • machone
    machone Posts: 1,559
    How long does a typical tube last?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • erniejade
    A long long time. 2-5000 hours depending on a lot of things.
  • machone
    DSkip. 6SN7
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    tonyb Posts: 33,072
    DSkip wrote: »
    Depends on the tube.
    ....and the operator.
  • doctor r
    doctor r Posts: 837
    Small signal tubes (9 pin and/or octal base) can last between 5000 and 10000 hours depending on the curcuit they are I used in. Power tubes have much shorter lives.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
