Cleaning Stylus With Mr. Clean Magic Eraser
Nightfall
I went to King Soopers yesterday and they had two versions of the Magic Eraser. I bought both just to be safe but can I use both or is one version not safe? One is the "Original" Magic Eraser which is a standard block/rectangle. The other is "Extra Power" Magic Eraser and has wavy sides to it. There is no ingredient list on either box so I'm really unsure of what the difference is.
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk
Original is the one I've seen recommended. Something is added to the others that is supposedly not good for the stylus.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
I use the original and have for more than a year, though I know nothing about the other FWIW.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Use the original with no soap or cleaners added. Place the ME under the stylus and lower it into it and the raise it up. Repeat a few times. That is all you need to do. If it is possible cut a small square and use some blue tack to attach it to a quarter to give it some mass. This is never used to "stroke" the stylus. Just dip into it. The fibers of the melamine foam (ME) have actual "sharp" edges that will scrape buildup off the diamond as it enters and leaves the foam. (Theoretically could grab the diamond in a bad way if it is stroked across it). I have used it for years with excellent results.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Extra Power is a tighter weave that claims it lasts 50% longer then the original. Both are safe on stylus.Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Been using it for a while and it works great, just don't move it while cleaning.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I would never use either, get some LP 9 and know your stylus is safe.Zu Soul Supreme
Coincident Frankenstein mkIII
Esoteric K-07
