I Want to buy - LSi series components
francis1967
Does anyone have any spare parts that I might buy from you?
I am looking for
4x 5-1/4" Diameter Dynamic Balance with Aerated Polypropylene cone, cast basket and rubber surround LSi series drivers
2x VIFA 1" Diameter Ring Radiator tweeter
2x Xovers as in trying to get fairly close to the xover in the LSiFx hoping I don't have to do too much modding.
Crossover Driver 1: LPF at 200Hz, 12dB/oct.
Driver 2: LPF at 2.4kHz, 12dB/oct.
Tweeters: HPF at 2.4kHz, 18 dB/oct.
Any two Dual gold plated 5-way binding posts for bi-amp/bi-wire
No switches needed for dipol/bipol. I am hardwiring bipol configuration.
You've probably guessed it already that I will be putting together a pair of surrounds. If you have any other ideas of components that might work well for me, please let me know. I am set on using the VIFA tweeter though. Anything other info is much appreciated.
Thanks,
Michael.
I am looking for
Thanks,
Michael.
Post edited by francis1967 on
If you can't find the components you're looking for, I have pairs of the LSi7's for sale.....comment comment comment comment. bitchy.
You can get the Vifa XT25 tweets from www.partsexpress.com and www.solen.ca I dont know if they are exactly the same as the LSi tweets but they are 4 ohm.Graham
Thanks for good info. I will check it out.
