MIT Magnum question
mikeyb128
mikeyb128 Posts: 2,885
I received my marantz 7702, have been tinkering over the past few days. I have some new magnum m3's for the front sound stage. Performed the xt32 calibrations, and the front stage is lifeless. Rear channels are lively as can be with my audioquest Columbias. I have the Interconnects impedance matched to my sunfire amp. No dynamic eq or volume enabled. I have tried everything. The front three are shite. So I decided to switch the impedance switch to medium instead of low. After the switch the front three came alive. It blew me the $&@! Away. Has anyone else experience this? I understand cable break in is required, but the amount of reviews for these cables and price I was a little bummed.
2 channel:
Theater:
    F1nut Posts: 51,912
    Nothing unusual there. The low, medium and high settings overlap a bit, so it's best to try a different setting to see if one works better than the other as you discovered.
  • headrott
    headrott Posts: 5,496
    When I purchased my BAT VK-200 here on the forum, I hooked up my MIT Shotgun S3's to it and started listening. I was disappointed with the sound I received from the amp. I then remembered that I did not adjust the impedance settings before hooking up the VK-200. My previous amp was the Pass Aleph 30 amplifier which had a much lower impedance than the VK-200. After adjusting the setting from the medium to the high hetting (above 100kH) the audio improved a lot.
    The impedance settings make a drastic difference in how the tonality, clarity and detail is presented to the listener (from my experience).
    The cable burn in also makes a big difference in what is presented to the listener. Particularly in the bass clarity, detail; high end clarity and detail, and the soundstage and imaging.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    "The cable burn in also makes a big difference in what is presented to the listener. Particularly in the bass clarity, detail; high end clarity and detail, and the soundstage and imaging."
    isn't that the truth. :)
  • Emlyn
    Emlyn Posts: 4,797
    mikeyb128 wrote: »
    Did you run the auto calibrations again after changing the impedance switches? What is the specified input impedance on the amp?
  • mikeyb128
    The input impedance on the sunfire is 24kohms. The low setting on the magnums is 5-50. So I found it weird that the medium setting sounds better. And I mean way better, nice crisp highs and the front sound stage blends seamlessly together, if I closed my eyes it would be like there was only one speaker. On low setting it was just boring. I have not re-run audessy after switching impedance settings, was something I tried late last night. I'm going to re-run things today.
    2 channel:
    Theater:
  • Emlyn
    Emlyn Posts: 4,797
    If the ranges are the same as on my Shotgun S1 interconnects, the mid setting starts at 40. As mentioned above, it can be best to try out the different settings as I think there is some flexibility in them. I am curious if the Audessy will affect the in room frequency response though. It could be that it is making the in room response flattened, which may be more "accurate" for movie soundtracks but not necessarily the best sounding to every listener. Interested in what you find out.
  • mikeyb128
    The impedance ranges on the magnum m3:
    Low 5-50
    Med 40-100
    High 90 and up
    The girl friend heads out in a few hours, then I have some peace and quiet to re-run audessy. Will report back with my findings. So far really loving the medium setting. Has livened things right up. Thanks for the quick responses.
    2 channel:
    Theater:
    F1nut Posts: 51,912
    Interested as well.
  • mikeyb128
    Verdict is in. Set the magnums to medium. Re-ran audessy. Did several different calibrations. Seems that is did flatten the in room response a bit. Tamed the highs a little. But overall the sound is still better, more of an airy, open sound, almost sounds louder. I have switched the magnums from low to medium, the low setting almost muffles the sound,Takes away from the quality. Overall I'm blown away by the drastic difference from the low to medium setting. I guess only REW would tell the honest truth, but I'm too lazy to pull out the computer and mic. I'm really satisfied with the sound right now. I think I still prefer how thorough mcacc is (despite no sub cal).
    2 channel:
    Theater:
  • Emlyn
    Emlyn Posts: 4,797
    Thanks for the follow up. I don't use any analog interconnects in my home theater system now, but do use MIT S3 speaker cables (no impedance adjustments on those) and found the auto calibration helps a great deal in what is normally an awkwardly bright acoustic space because of the number of windows. The calibration in my case helped tame the brightness of the sound without impacting clarity, which is why I was guessing the calibration may have had some impact on your system.
    Glad you found a solution!
