Burgers
  • vmaxer
    vmaxer Posts: 5,120
    Where you at @tonyb ??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • cfrizz
    cfrizz Posts: 13,415
    For the burgers preseason meat with salt pepper, and a little mayo to retain moisture, especially if you get low fat content beef, then make your patties, don't skimp on the size of the burger. When on the grill do not press on them and only try to flip them once.
  • rooftop59
    rooftop59 Posts: 8,121
    @msg I have never heard of lemon and ginger in a burger...hmm gives me all kinds of ideas. Instead of bouillon u could throw some soy sauce in there. Add scallions, cilantro and garlic and maybe a dash of sesame or peanut oil. All the sudden you got a nice Asian burger. Serve it between ice berg lettuce and its like lettuce wraps...for men!!!
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,452
    Haha, maaan... all that! Just light on the sesame oil, right? That stuff is POTENT! I had a hard lesson in that - I gotta read closely; TBSP is not the same as TSP. With sesame, you don't make that mistake twice. Gotta admit to lettuce wrap gluttony, esp with that spicy hot oil stuff?
    Neither had I before, and I know, it sounds weird for that stuff to go into burgers. Sometimes I'll use the same recipe for turkey burger meatballs.
  • Mikey081057
    Mikey081057 Posts: 7,127
    80/20 ground beef chuck or sirloin and Jimmy Dean Sausage and put an egg on that burger
    Garage | Polk Monitor 5B's
    gudnoyez Posts: 8,161
    Ground venison burgers here, the only way the Wife will eat venison. 2lbs ground venison mixed with real bacon chunks, and grated cheese served on a local bakery bun slightly toasted
    On the grill lettuce tomatoe bacon strips well done and topped with guacamole.
    Brats from the butcher Atomic, Hawaiian, Maple, Pizza, Apple, Bacon Cheddar, placed in boiled beer for a minute or two then also placed on grill off to the side for that they don't split. The Atomic Brats live up to their name.
    tonyb Posts: 33,072
    Ok guys....question, how long do you boil the Brats for ? I've eaten them plenty, but never actually made them with beer myself. Some say 5-10 minutes, above says only a few.....will they crack if boiled too long ?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited June 2015
    tonyb wrote: »
    I think you'll get the range of responses.
    I parboil my brats with beer, water, some olive oil, green onions, white onions, and garlic - about 4 minutes. They don't split - at least mine haven't.
    I use the grill basically to put on some nice brown sear marks and finish the cooking. It shouldn't take long at all.
    I have found that if I leave the brats over too high/direct heat for too long they 'spring a leak' someplace in the casings and they then spray out all of the liquid/moisture. This makes them dry-ish.
    So watch the brats and listen for that hissing sound of the brats loosing their moisture.
    You can always put the brats back in the pot to re-soak before serving.
  • Erik Tracy
    edited June 2015
    Inspired by Tony - going to do up some burgers for the family today.
    1/2 patties (two teenage boys can put the food away fo-sho!), with a drizzle of olive oil, crushed up French's crispy onion, some steak seasoning and some finely diced yellow onion. All mixed up then into the patties with a final dusting of my local butcher's specialty seasoning.
    Will serve with grilled onions, garden tomato and lettuce. Sliced cheese, ketchup, mustard, mayo per eater preference.
    Going to let the grill get to max temp of 550F before putting the patties on to get a nice sear/char.
    I hope Tony survives the day.... :)
  • vmaxer
    vmaxer Posts: 5,120
    rooftop59 wrote: »
    I usually mix a pound of ground beef with one egg, a half cup of shredded sharp cheddar, a quarter cup of panko bread crumbs, 4-6 slices of crumbled bacon, a dash of worcheshire, several cloves of minced garlic, and sea salt and fresh ground pepper. Make the patties and pop them in the freezer for about 20 minutes. I put another slice of cheddar on them when they are almost done cooking, and I serve them on toasted onion buns with all the fixins.. About the most moist and flavorful burger you ever had!
    For grilled pizza, I often use this recipe: http://www.epicurious.com/recipes/food/views/grilled-pizza-with-spicy-italian-sausage-103234
    I don't make the dough. I either buy naan bread or fresh dough from the store.
    Well, the wife is gone to get some groceries now. We are going to try this out.
    I have gained weight just thinking about them.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • footwedge
    footwedge Posts: 475
    edited June 2015
    Get some prime ground chuck from the meat market and tell them not to compress the meat when packing. Before making the patties, I brake the meat into small pieces and add salt and pepper. Make the patty by gently pressing the meat together just enough so that it holds together. Cook on hot charcoal grill and add a good sharp cheddar. Serve on toasted bun with red onion, vine ripe maters and guest choice of condiments.
    Sometimes simpler is better and key is not to over compress the patty.
  • shawn474
    shawn474 Posts: 3,052
    Not sure if this has been mentioned yet as I havent read the entire thread but my recipe is simple and handed down from my mother in law. Its so simple it is stupid but really is tasty.
    One pack of lipton onion soup mix with your burger meat. Form patties and grill. It is stupid good and takes 12 seconds to prepare.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • vmaxer
    vmaxer Posts: 5,120
    footwedge wrote: »
    Will do what I can there, the wife went to get everything.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • afterburnt
    afterburnt Posts: 7,892
    About 1/4 I Italian sausage hot or mild to some 20 percent ground beef. They will set your grill on fire so you got to watch em. Or some finely diced butter, got to be frozen and that will set the grill on fire too. I use some dehydrated onions, they seem to soak up some of the juice while the cook. Anyway if you use anything too lean you get hockey pucks.
  • vmaxer
    vmaxer Posts: 5,120
    tonyb wrote: »
    Sunday I get the pleasure of having a birthday party for my 2 year old grandson. About 40 people, 30 adults and 10 kids will be trying their best to destroy my home. Suckers can drink too, the adults....not the kids. Just spent a small fortune at Binnys on wine/beer/vodka.
    Anyway, was thinking Burgers and Brats to feed this small army. Maybe some dogs for the kiddies but the Brats have to be beer Brats for me. Burgers....saw a video of the reproduction of the Shakeshack burger I think I want to try. For those unfamiliar with them, they use a combination of 80/20 ground beef, ground sirloin, and ground Brisket. Plus the secret sauce....which is no secret, lol.
    Any of you guys have a better Burger recipe ? Whose Bratts do you like ? Keep in mind I'm in Chicago so has to be something available here. You guys boil your Bratts in beer and onions first before hitting the grill ?
    So, how did it go?? Or is it still going??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    txcoastal1 Posts: 13,513
    He's probably beating heathen's off his audio gear :p
  • ken brydson
    ken brydson Posts: 9,005
    txcoastal1 wrote: »
    Or he's locked out of the house in his drawers...
  • vmaxer
    vmaxer Posts: 5,120
    Well the burgers were a huge hit, thanks a lot.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hochpt21
    hochpt21 Posts: 5,423
    Don't know how I missed this thread first time around. But I only buy the uncooked brats...boil them in onion, garlic and beer...then throw them on a low grill until they just start to sputter a bit...not crack fully open.
    MMMMM....that's some good brats :)
    I also like experimenting with different beers...don't just dump a PBR in there. Some of those fruity-type beers can really add a good flavor to them.
  • rooftop59
    vmaxer wrote: »
    Good to hear man! I've gotten lots of compliments on those over the years. I think the recipe originally came from epicurious, but I can't find it anymore. Glad u enjoyed em!
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,072
    The day went fantastic gents. Nixed the grilled pizza idea mainly because it would have taken too much of my time to make so many. Stuck with 40 burgers, 60 Brats, 6 lbs of Italian sausage, Stuffed mushrooms, about a dozen dogs, plus all the fixings. 3 cases of beer, 12 bottles of wine, Huge bottle of Absolute, kept the adults busy while I tended the grill. The wife kept saying we had way too much food, but at the end we barely had enough for ourselves for lunch today. So I guess people liked it.
    Best part....dessert, Aside from the birthday cake, we had the great idea of having a Sunday bar. 4 assorted ice creams from Oberweiss.....a local dairy/brand, all the toppings, chopped up Oreo's....Reeses PB cups....M&M's....gummy Minions...assorted sprinkles, cherries......hot fudge, whipped cream, heck.....can't even remember all the topping s we had out for them.
    Knew it would be a hit with the kids, but darn if the adults weren't throwing elbows to secure their place in line. It's also common knowledge within my family and friends that no kid leaves my house without doing whipped cream shots, no matter how tired or late it is. Kids don't usually have a problem coming back to my house.
    I usually throw one big blow out birthday for each of the Grandkids. The rest are up to the parents. This 2 year old grandson was just relocated back home from Florida, daughter decided family is what was needed to help raise her son, light bulb !!
    Anyway......good food and drink and fun times with family, doesn't get much better than that. Thanks to you guys for all the tips, recipes....you guys rock.
  • vmaxer
    vmaxer Posts: 5,120
    Wow, I wish I were close to you B)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • rooftop59
    Cool tony. Sounds like a blast! U definitely have the gift of hospitality my man.
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,072
    vmaxer wrote: »
    Heck man, I'd go broke if you guys lived by me. lol.
    but...we'd have a heck of a time. ;)
  • cfrizz
    I'm glad it was a success Tony!
  • decal
    decal Posts: 3,205
    Ain't it sad that a kids party turns into a drinkfest for the adults?
