LP cleaning machines....
TroyD
TroyD Posts: 13,124
edited August 2004 in 2 Channel Audio
I have a bunch of old and dirty LP's. I've given some thought to investing in a record cleaning machine, however, I don't know much about them and they seem a bit pricey.
I was hoping that maybe Ken or madamax might be able to provide some insight in LP cleaning and machines....
Thanks in advance
BDT
  • madmax
    madmax Posts: 12,434
    edited August 2004
    The VPI HW-16.5 for $450 is awesome! They seem to last forever so I would check out a used one. Check out AA or Galen Carroll (sp) for new ones. It is cool because you can sit the lp on the table, scrub fore and aft then vacuum up the crud. The other cleaners only vacuum. To scrub the lp with those you would have to have a good place to lay it while doing the scrubbing. Much more chance of harming the vinyl.
    madmax
    Vinyl, the final frontier...
