WTB: MIT Shotgun S3 Interconnects and Speaker Cables
I could use some MIT Shotgun S3 Interconnects and Speaker Cables.
Just missed a couple of the deals there in the FM.
If you happen across this post, please keep me in mind if you have any you'd like to move.
Specifically,
15ft speaker cables
10ft speaker cables
15ft interconnects (1pr req'd, possibly 2pr)
1m or 2m interconnects
These are just specific needs as of now, and I'm open to consideration of other lengths available, as well.
  • headrott
    headrott Posts: 5,496
    You have a PM to (hopefully ) help you out.
  • dhart86
    dhart86 Posts: 1,594
    will let you know if a 10ft S3 pair of speaker cables becomes available
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
    msg Posts: 10,458
    excellent guys, thank you
  • quickr1
    quickr1 Posts: 414
    Pm me if your still interested in the interconnects.
    msg Posts: 10,458
    edited June 2015
    thanks, PM replied
    still looking for the Shotgun S3's, specifically.
    Am open to consideration of other MIT cables - possibly AVt, CVT/Terminator 2's etc, but will keep this post open until I can acquire S3's
    headrott wrote: »
    You have a PM to (hopefully) help you out.
    in the works
    dhart86 wrote: »
    I'm still interested if these come up
    Post edited by msg on
  • dhart86
    pm sent
    Main Rig:
    Second Rig:
    msg Posts: 10,458
    annnnd replied.
    getting there, guys, thanks.
    Still need a pair of 15ft Shotgun S3's Speaker Cables, and open to S3 IC's of varying length.
  • headrott
    Replied to your PM @msg. Should have those S3 IC's out to you soon.
    msg Posts: 10,458
    Keiko wrote: »
    Posted this earlier today. 70% off. mikeyb took advantage, but give them a call. Might have something left for you.
    http://forum.polkaudio.com/discussion/167987/mit-clearance
    Thanks K - I did find a little something last night. it's good having some guys around with the feelers out!
    headrott wrote: »
    Replied to your PM. Should have those S3 IC's out to you soon.
    thank you suh! indeed, looking forward.
    hard to believe 2 months ago I was a bit of cable skeptic, though open to the experience.
    I don't understand it, it defies logic, but I simply can't deny the difference they make. even with what little experience I've had, I'd like to try my ear at some blind testing. we probably need another cable thread... I jest, I jest :)
