My DNA-0.5 died.....
My first honest gear failure, it figures it has to be the McCormack. This amp has been such a great purchase.... I am not really mad, just disappointed.
I had the amp unplugged over night as we had the possibility of strong storms rolling through. Plugged it in this morning, when I flipped the switch, there was a brief flicker of light, then nothing.
I hooked up some testing speakers, powered it up, just to make sure the light hadn't burned, but there is no output.
there are four internal fuses, all test fine with a dmm....
I had been considering upgrades from SMc... maybe this is a sign. Shot him an email this morning....
It's gonna be hard to hook up my NAD 2150 for a while.....
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
«13
    tonyb Posts: 33,072
    Dang, sorry that happened pal. Give Steve a call and see what he says. Too good of an amp to not fix.
  • vmaxer
    vmaxer Posts: 5,120
    What Tony said, keep us posted.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • 11tsteve
    11tsteve Posts: 1,166
    I shot an email to SMc... is calling a preferred method?
    And I am in total agreement. Quite honestly, this is the first purchase I have made which made me feel I had taken maybe just a tiny step out of the mid-fi range. I love everything about the amp, but the low end control and clarity was quite startling.
    After I talk to Steve a bit, I will have to decide how far to upgrade. Of course money is an issue, but if I already have to ship the amp.....
    Clifton Audio might also be an option if he is too busy....
    Polk Lsi9
    Keces DA-131 mk.II
  • MrBuhl
    MrBuhl Posts: 2,419
    Ugh - that's a drag.
    I looked at the deluxe upgrade pricing on my DNA-1. Maybe your repair would be included in the upgrades and you could end up with both done if you're lucky - here's a pricing link I found.
    http://smcaudio.nfshost.com/upgrades.php
    It's an old 2009 price list but gives you an idea anyway.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    tonyb Posts: 33,072
    Ask if they have any authorized repair joints in your neck of the woods....doubt it though as they aren't that big to warrant it. Doesn't hurt to ask. I think he's located in southern Cali, where are you ?
    You sure those fuses are OK ? Be a SOB if you had to ship it and they changed a fuse. Fuses are cheap, go buy some and see what happens.
  • WLDock
    WLDock Posts: 3,073
    11tsteve wrote: »
    Don't rule out a local tech. Its just an amp...chances are its something in the power supply. There might be a local guy that repairs all types of gear that can handle the repair no problem.
    However, if you want to upgrade....send it in and pay the big bucks.
  • 11tsteve
    Smack dab in the middle of Iowa. I have checked previously, and would feel more comfortable handing it over to either The Man himself, or someone he recommends such as Clifton.
    And Tony has a good point. I'll see what I can locate for fuses.
    Polk Lsi9
    Keces DA-131 mk.II
  • vc69
    vc69 Posts: 2,500
    Following
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • 11tsteve
    Ok... got a call from SMc right away this morning... looks like I might end up feeling stupid. There is an external fuse tray by the AC recepticle, which he said many, many people miss. Especially since folks don't always have manuals with the used trade. So as SOON as I get home from work.....
    It was a great conversation. .. one I fearly wish I hadn't been at work.
    They have an upgrade special right now. Complete rebuild for $1500.... wish I had the coin.
    I'll post back tonight about the fuse...
    Polk Lsi9
    Keces DA-131 mk.II
  • oldrocker
    oldrocker Posts: 2,590
    Crossing my fingers and toes for you it's just the fuse thing..
  • 11tsteve
    thanks very much. It will be worth feeling stupid.
    Polk Lsi9
    Keces DA-131 mk.II
  • MrBuhl
    MrBuhl Posts: 2,419
    It is better to be lucky than good often times! Keeping my fingers crossed!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • 11tsteve
    Ok McCormack included a spare fuse... mine is gone, and the main fuse is black and blown. It is a 5A 125V slow blow... and I was told they are now recommending 6.2A slow blows, so I am off to find some.
    We had thunderstorms rolling through last night, and I had unplugged the gear.... so hopefully I did something unknowingly when I plugged it back in this morning, or there was a small spike that blew the fuse.
    Thanks everybody for the well wishes.
    Polk Lsi9
    Keces DA-131 mk.II
  • MrBuhl
    MrBuhl Posts: 2,419
    That's great news man - congrats!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • vmaxer
    vmaxer Posts: 5,120
    I thought about asking about, but assumed you had checked it. Congratulations on it being a simple fix.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • 11tsteve
    vmaxer wrote: »
    The no manual thing, and I "panicked" instead of Googling. Honestly, when I checked the back panel, all I have ever seen is the usual fuse installs. Didn't know this existed, so when the McCormack tech asked if I had checked the rear panel fuse, it was an audible groan on my part.
    Everything is fine, and now I am anxious to get the new-to-me Pangea power cable I just purchased from acmf74.
    Side note, amongst the many things that were discussed, the McCormack guys are adamant about leaving these amps powered up 24/7. It was suggested I change my evil ways with powering down my amp (barring severe weather outbreaks).
    Polk Lsi9
    Keces DA-131 mk.II
    tonyb Posts: 33,072
    Good to know Steve, and sure hope that fuse is your answer. You hardly ever hear of a McCormack amp biting the dust.
  • 11tsteve
    tonyb wrote: »
    yup. all good.... nothing but a red face to show.
    In a way, it was just worth it to talk to the tech there. And to get a personal call within 2 hours of sending an email. So top notch.
    Next step is to drop in a Hi-Fi Tuning Silver Star fuse.... pricey, but how will I ever know if I don't try one.
    Polk Lsi9
    Keces DA-131 mk.II
  • Jhayman
    Jhayman Posts: 1,548
    That's Great News Steve...
    Do you recall the tech saying ALL McCormack amps should be on 24/7 or just your 0.5
    Can I trouble you for the number you called, I would like to give them a call.
    tonyb Posts: 33,072
    Jhayman wrote: »
    Probably as Skip suggests. I would think because he builds all his amps very similar by using multiple smaller caps instead of a couple coke can sized ones. Maybe the constant charging and discharging of all those caps coupled with his design isn't a good thing.
  • Jhayman
    edited June 2015
    Ok Thanks Skip..
    I'll leave my 500 powered up
    Forget I asked for the number, I missed the link in the thread...Good Morning need that cup of Tea..
    tonyb Posts: 33,072
    How you diggin' that 500 btw ? Frickin' beast isn't it ?
  • 11tsteve
    edited June 2015
    tonyb wrote: »
    Jhayman wrote: »
    yup... all of you are correct. He said "these amps"... really how I took that is everything Steve designs... and what tony said.
    I have seen these things discussed here, but it is the initial surge of voltage application every time it is powered up which wears on the components and reduces life span. All the internals are meant to stay on... plus, his comment was it takes 2 or 3 days for the transformer to really reach its fullest potential. the DNA 0.5 draws the equivalent of a 75W bulb at idle, so not much draw there.
    Other things discussed, besides replacing the 5A fuse with 6.3A:
    If the amp gets sent in, they now reduce the BIAS voltage from around 63mA to around 45 mA.
    I should look into installing a grounding spike, which he emailed info and pictures.
    try placing the lid on, but no screws.
    I should look into better gear isolation.....
    All of these things will improve detail and soundstaging.
    Jhayman wrote: »
    I contacted them through the form on the website http://smcaudio.com/
    The form asks for your phone number.... and they called me. Judging by the time difference, it seems he called not to long after he walked in and read his email.
    Polk Lsi9
    Keces DA-131 mk.II
  • Jhayman
    Diggin every minute I use it, lol
    Plenty of balls and Great refinement, also I just picked up a McCormack Map-1 to be used strictly as 2 channel pre, I also still have my VTL 5.5 pre which this morning I'm in the process of running both pre's into the 500 so I can select a keeper..
    tonyb Posts: 33,072
    Cool beans, never got an ear on Steve's pre amps, those VTL's though are awesome in their own right. BTW...whats those tubes on the floor ?
  • Jhayman
    VTL Compact 100 mono blocks
  • Jhayman
    tonyb Posts: 33,072
    edited June 2015
    More good choices my friend, how they sounding for ya ? I'm guessing a little more tone, better soundstage, but not as near the bass slam of the DNA 500.
  • Jhayman
    Well they sound Fantastic when the left monoblock does not develope an issue.
    They are working fine at the moment, but I really have to make my mind up where I'm going to keep my main listening area..
    I have to much gear for the area I prefer and it will all fit in the basement but I do not wish to be a cave dweller any longer..sigh
    Here's what I am stuck with upstairs..
    tonyb Posts: 33,072
    Dude, you really need to clean out that room, the sound would improve immensely. Is that an optical thing, or does that floor have a major dip in it ?
    Consolidate my friend. Now that I see the size of that room, maybe a good integrated from the likes of AYON might be more appropriate.
