can I fry my speakers at "0" ?
afterburnt
afterburnt Posts: 7,892
Alice in chains sounds best at "0" sue me...
  • Nightfall
    Nightfall Posts: 10,084
    Your ears will tell you when clipping is happening. Hopefully. :p
    afterburnt wrote: »
    Village Idiot of Club Polk
    tonyb Posts: 33,072
    Yes you can....but hey, it's your coin...spend it as you see fit. :)
  • sucks2beme
    sucks2beme Posts: 5,683
    Time for more wattage. Or a hearing check.
  • Upstatemax
    Upstatemax Posts: 2,737
    As long as you're not over extending the woofers and pushing the amp to clipping, you should be fine.
    With my kids, there is a very good reason that I have my Denon set to a max volume. Loud enough to scare them if little fingers start spinning knobs, but not loud enough to hurt anything.
    mhardy6647 Posts: 35,011
    edited June 2015
    The big enemy of loudspeakers in terms of applied (electronic signal) power is heat. The wire in the driver voice coils, like the grind of the gristmills of the gods, is exceeding fine -- too much power dissipated through the voice coil can generate enough heat to physically distort the voice coil (causing "dragging" of the VC in the magnetic gap), or even literally burning the VC open.
    We'll leave the topic of exposure to high SPL and irreversible hearing damage for another time ;- )
  • afterburnt
    Do you think that this would be less of an issue with Rtia9's?
  • Nightfall
    afterburnt wrote: »
    No, sir. Clipping is clipping. It might be less an issue with extremely efficient horn loaded speakers though as your ears are likely to start bleeding before you hit "0" anyway. :p
    afterburnt wrote: »
  • afterburnt
    Ok I rarely need to listen to angry music lol. Most stuff is plenty loud in minus territory but Alice in chains is no fun without a little pain ;^)
    msg Posts: 10,452
    afterburnt wrote: »
    oh. well then you should practice stage diving with no crowd.
    if you're a real fan, that is.
  • afterburnt
    Dive? I wish! I fall down pretty good though
  • steveinaz
    steveinaz Posts: 19,545
    3 things;
    1. Amplifier clipping
    2. What is the sepakers max SPL specification?
    3. Room size
