Isolation Rubber / Anti-Vibration Pads, Etc - What and Where to Source?
msg
msg Posts: 10,450
Still trying to settle on a system setup, but been in desperate need of a rack/organization.
In the meantime, I'm just using some adjustable industrial wire shelving.
Most of the gear is on individual shelves, on top of pieces of MDF of approx 18"x17".
Between the MDF and wire shelves, I've got little pieces of acoustic mastic. This stuff's really thin though, about 3/32", and for now is just serving more to keep MDF in place.
I'd like to source some rubber isolation disks or anti-vibration pads to use between the shelves and MDF until I get situated and get a proper rack together. I think I'd like to keep the isolation rubber to between 1/8" to 1/4". Thinking four points, like now.
Any ideas, or better suggestions to accomplish what I'm trying to do?
    SCompRacer Posts: 9,084
    edited May 2015
    Dynamat is a sound deadener although a nine sheet pack (18" x 32") is pricey. You can buy it in smaller sizes and amounts. It's .067" thick.
    Look for Sorbothane sheets, usually 1/8" to 1/2" thick.
    Music Direct has a page of vibration control products. Vibrapods are supplied in various weight capacities to be used under gear, 9/16" tall though. They sell some 3M damping sheets, thin at 15/1000ths thick.
    http://www.musicdirect.com/c-672-vibration-control.aspx
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • hochpt21
    hochpt21 Posts: 5,423
    edited May 2015
    I use both of the above linked products with great results. I can't honestly say one is better than the other. They both work well for the price.
    Edit...the sorbothane balls WILL leave marks on your equipment so wrap them in clear plastic before using them.
  • heartystatue
    heartystatue Posts: 329
    For just temporary use Home Depot has clear self adhesive cabinet bumpers. 5/16" 24 pack for 3.99. I think would work fine.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
    EndersShadow Posts: 17,687
    edited May 2015
    hochpt21 wrote: »
    So like seran wrap
  • hochpt21
    hochpt21 wrote: »
    So like seran wrap
    Yes, but I didn't know how to spell seran, so I said clear plastic B)
    hochpt21 wrote: »
    hochpt21 wrote: »
    So like seran wrap
    Lol... I'm not promising I spelled it right hehehehe
  • hochpt21
    hochpt21 wrote: »
    hochpt21 wrote: »
    So like seran wrap
    Good thing we have this newfangled interweb thingy to double check!!
    Saran Wrap :)
    msg Posts: 10,450
    edited May 2015
    thanks guys, I'll have a look at some of these things.
    I have some of those little feet from HD from another project - if it's the same ones, they seem kind of stiff? I was thinking I should be using something a little squishier and vibration absorbent?
    SC - thanks, yes. the stuff I'm using is similar to Dynamat. I bought it in bulk several years ago from McMaster for lining the doors and cabin of a vehicle I was working on. It works great as deadening, but isn't as pliable or squishy as Dynamat, so Dynamat would probably work better. I think I think sticks better, too.
    I do like the Sorbothane sheet idea. Those offerings may be the ticket.
    I think I can use those pods in various other projects. I need to replace some feet that have gone sticky on another piece of equipment.
    How does Sorbothane hold up to heat? Is this how it weeps/stains? Or is it just one of those rubber products that always seems slick/wet in general?
    Sorbothane - I just looked this up. it's used in insoles, too?!? so I could just go buy some Dr. Scholl's?
  • hochpt21
    msg wrote: »
    It's always kind of sticky/slick feeling.
    msg Posts: 10,450
    okay, thanks.
  • Joey_V
    Joey_V Posts: 8,600
    I think some of those feet leave marks so be careful with it. Use wax paper or just paper to buffer between your equipment and those feet.
    txcoastal1 Posts: 13,499
  • vmaxer
    vmaxer Posts: 5,120
    The more you pay the better it works :o
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    msg Posts: 10,450
    edited May 2015
    xcapri79 wrote: »
    Try these. I've used sorbothane under my bookshelf speakers.
    http://amzn.to/1M1OU4d/
    thanks x, I'll check these out
    Joey_V wrote: »
    cool, thanks.
    Zero wrote: »
    Go to your local Bed Bath and Beyond. Buy a 20-pack of cedar discs for $8. Put two under either the feet of your gear, or under the chassis itself. Done.
    these? http://bit.ly/1M1N4QP
    how will cedar disks work? aren't these just wood?
    msg Posts: 10,450
    edited May 2015
    txcoastal1 wrote: »
    Cork and Isolation pads .29ea
    http://bit.ly/1M1Oyuw
    Same stuff for 10X the price
    http://ebay.to/1M1OF9m
    yeaaaaah, I saw these things!
    I was wondering - wouldn't the cork be too rigid?
    Isn't the whole idea here to soak up the vibration and not transfer it?
    I see the rubbery stuff on both sides. curious about these. would definitely have to have the more expensive ones... lol
    F1nut Posts: 51,674
    Vibrapods and Sorbothane will definitely stain whatever they come in contact with. They also have weight limits.
    Look into closed cell foam rubber gasket material in the thickness desired.
    msg wrote: »
    I saw these things!
    Rubber is 4 to 6 times denser than cork so in my mind it would be a better iso pad
  • vmaxer
    vmaxer Posts: 5,120
    txcoastal1 wrote: »
    msg wrote: »
    I saw these things!
    Depends on the rubber, many choices.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    vmaxer wrote: »
    txcoastal1 wrote: »
    msg wrote: »
    I saw these things!
    kg/cu.m.
    Cork, solid 240
    Rubber, caoutchouc (Natural) 945
    Rubber, manufactured 1522
    Rubber, ground scrap 481
  • vmaxer
    vmaxer Posts: 5,120
    txcoastal1 wrote: »
    vmaxer wrote: »
    txcoastal1 wrote: »
    msg wrote: »
    I saw these things!
    kg/cu.m.
    Cork, solid 240
    Trust me there are a crazy number of rubber formulas all designed for different purposes.
    I work in the field of rubber and plastic molding for the automotive industry.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    I believe that but the point is most of those Home Depot rubber feet are more than likely denser than cork
    Those .29 cent ISO pads with cork and rubber are made for HVAC and washing machines
    Going to be hard to beat the value and isolation
    msg Posts: 10,450
    txcoastal1 wrote: »
    kg/cu.m.
    Cork, solid 240
    what does this mean, exactly?
    what numbers do we look for for absorption? this is isolation, correct?
    side question - this has me thinking about speaker spikes and pads, coupling/dcoupling; isn't this kind of similar? when we say isolate, what are we actually talking about? removal of outside vibration effect in this case.
  • leftwinger57
    leftwinger57 Posts: 2,917
    If you decide to got the Dynamatt route here's what I did. Being a man of no means and I did check out some of the squares at IEE near me I said f to that (way to expensive ) and asked who else besides speaker modders use the stuff. Well it turns out most audio car installation places use it to deaden trunks, doors and floors. I went to one close by me and ask 1st do they use the sh&t and then when the answer was yes I asked if they had scraps around and again it was yes and they gave enough to do about 6 pairs of 2Bs some in nice full slabs Notice on the pic the passives were not fully covered, that I rectified and all now are7nb1swv7nr03.jpg
    . I did offer coffee money but they would not even take that. I did not use it for feet or interior walls of sources just my speaker baskets w/ fantastic results which all here can atest to. Good luck it's an easy mod. Oh on my sig you will notice Black-Hole-5 that was a C/L buy for $12 for a full sheet and some scraps as well. That stuff works as advertized.
  • leftwinger57
    Not to drone on but for the feet of most of my gear I bought from the $ store cork coasters full sets and of course since they were red I repainted them my world famous HD flat black. I try to repurpose anything I can to avoid paying top dollar prices. Speaker cable and i/c cords I've learned do make a difference to a point and do not skimp there.
    edited June 2015
    txcoastal1 wrote: »
    I use this stuff under a lot of my gear and it works quite well. I also have a hook-up in that my dad works for a RX company in the research department as a chemist, so I have him bring home the industrial size beaker stoppers and use those as well. We've used those as risers for audio gear (and beds) due to their size and composition with great success.....
  • muncybob
    muncybob Posts: 3,231
    Yep, if you search for those type pads the user comments are dominated by "I use these in my audio system"...just ordered 20.
    Yep, my name really is Bob.
  • classic carl
    classic carl Posts: 661
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk RT55i ~ Polk Audio RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI 200C ~ Dayton Audio SUB-1200
