Isolation Rubber / Anti-Vibration Pads, Etc - What and Where to Source?
msg
Still trying to settle on a system setup, but been in desperate need of a rack/organization.
In the meantime, I'm just using some adjustable industrial wire shelving.
Most of the gear is on individual shelves, on top of pieces of MDF of approx 18"x17".
Between the MDF and wire shelves, I've got little pieces of acoustic mastic. This stuff's really thin though, about 3/32", and for now is just serving more to keep MDF in place.
I'd like to source some rubber isolation disks or anti-vibration pads to use between the shelves and MDF until I get situated and get a proper rack together. I think I'd like to keep the isolation rubber to between 1/8" to 1/4". Thinking four points, like now.
Any ideas, or better suggestions to accomplish what I'm trying to do?
Dynamat is a sound deadener although a nine sheet pack (18" x 32") is pricey. You can buy it in smaller sizes and amounts. It's .067" thick.
Look for Sorbothane sheets, usually 1/8" to 1/2" thick.
Music Direct has a page of vibration control products. Vibrapods are supplied in various weight capacities to be used under gear, 9/16" tall though. They sell some 3M damping sheets, thin at 15/1000ths thick.
http://www.musicdirect.com/c-672-vibration-control.aspx
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I use both of the above linked products with great results. I can't honestly say one is better than the other. They both work well for the price.
Edit...the sorbothane balls WILL leave marks on your equipment so wrap them in clear plastic before using them.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
For just temporary use Home Depot has clear self adhesive cabinet bumpers. 5/16" 24 pack for 3.99. I think would work fine.
HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC. -
So like seran wrap
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Lol... I'm not promising I spelled it right hehehehe"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »
Good thing we have this newfangled interweb thingy to double check!!
Saran Wrap
thanks guys, I'll have a look at some of these things.
I have some of those little feet from HD from another project - if it's the same ones, they seem kind of stiff? I was thinking I should be using something a little squishier and vibration absorbent?
SC - thanks, yes. the stuff I'm using is similar to Dynamat. I bought it in bulk several years ago from McMaster for lining the doors and cabin of a vehicle I was working on. It works great as deadening, but isn't as pliable or squishy as Dynamat, so Dynamat would probably work better. I think I think sticks better, too.
I do like the Sorbothane sheet idea. Those offerings may be the ticket.
I think I can use those pods in various other projects. I need to replace some feet that have gone sticky on another piece of equipment.
How does Sorbothane hold up to heat? Is this how it weeps/stains? Or is it just one of those rubber products that always seems slick/wet in general?
Sorbothane - I just looked this up. it's used in insoles, too?!? so I could just go buy some Dr. Scholl's?I disabled signatures. -
It's always kind of sticky/slick feeling.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I think some of those feet leave marks so be careful with it. Use wax paper or just paper to buffer between your equipment and those feet.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Cork and Isolation pads .29ea
http://www.supplyhouse.com/DiversiTech-MP-2C-Rubber-Cork-Anti-Vibration-Pad-2-x-2-x-7-8?gclid=Cj0KEQjw4qqrBRDE2K_z7Pbvjo8BEiQA39AImXQrCI1X_Fy55fsLOvR07VvjorRhzDWUaCCWV-BlZFkaAvfs8P8HAQ
Same stuff for 10X the price
http://www.ebay.com/itm/Audiophile-Cork-Rubber-Isolation-Pads-Isoblocks-One-1-set-of-four-4-pads/201356286805?_trksid=p2141725.c100338.m3726&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20141212152715&meid=ccc49a93c5324cbca1279e6d2c238665&pid=100338&rk=1&rkt=25&sd=1915729215892-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
The more you pay the better it works
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
thanks x, I'll check these outTry these. I've used sorbothane under my bookshelf speakers.
http://amzn.to/1M1OU4d/
cool, thanks.I think some of those feet leave marks so be careful with it. Use wax paper or just paper to buffer between your equipment and those feet.
these? http://bit.ly/1M1N4QPGo to your local Bed Bath and Beyond. Buy a 20-pack of cedar discs for $8. Put two under either the feet of your gear, or under the chassis itself. Done.
how will cedar disks work? aren't these just wood?
yeaaaaah, I saw these things!txcoastal1 wrote: »Cork and Isolation pads .29ea
http://bit.ly/1M1Oyuw
http://ebay.to/1M1OF9m
I was wondering - wouldn't the cork be too rigid?
Isn't the whole idea here to soak up the vibration and not transfer it?
I see the rubbery stuff on both sides. curious about these. would definitely have to have the more expensive ones... lol
Vibrapods and Sorbothane will definitely stain whatever they come in contact with. They also have weight limits.
Look into closed cell foam rubber gasket material in the thickness desired.Political Correctness'.........defined
President of Club Polk -
I saw these things!
Rubber is 4 to 6 times denser than cork so in my mind it would be a better iso pad
txcoastal1 wrote: »
Depends on the rubber, many choices.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
txcoastal1 wrote: »
kg/cu.m.
Cork, solid 240
Rubber, caoutchouc (Natural) 945
Rubber, manufactured 1522
Rubber, ground scrap 481
txcoastal1 wrote: »txcoastal1 wrote: »
kg/cu.m.
Cork, solid 240
Trust me there are a crazy number of rubber formulas all designed for different purposes.
I work in the field of rubber and plastic molding for the automotive industry.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I believe that but the point is most of those Home Depot rubber feet are more than likely denser than cork
Those .29 cent ISO pads with cork and rubber are made for HVAC and washing machines
Going to be hard to beat the value and isolation2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
what does this mean, exactly?txcoastal1 wrote: »kg/cu.m.
Cork, solid 240
what numbers do we look for for absorption? this is isolation, correct?
side question - this has me thinking about speaker spikes and pads, coupling/dcoupling; isn't this kind of similar? when we say isolate, what are we actually talking about? removal of outside vibration effect in this case.
If you decide to got the Dynamatt route here's what I did. Being a man of no means and I did check out some of the squares at IEE near me I said f to that (way to expensive ) and asked who else besides speaker modders use the stuff. Well it turns out most audio car installation places use it to deaden trunks, doors and floors. I went to one close by me and ask 1st do they use the sh&t and then when the answer was yes I asked if they had scraps around and again it was yes and they gave enough to do about 6 pairs of 2Bs some in nice full slabs Notice on the pic the passives were not fully covered, that I rectified and all now are
. I did offer coffee money but they would not even take that. I did not use it for feet or interior walls of sources just my speaker baskets w/ fantastic results which all here can atest to. Good luck it's an easy mod. Oh on my sig you will notice Black-Hole-5 that was a C/L buy for $12 for a full sheet and some scraps as well. That stuff works as advertized.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Not to drone on but for the feet of most of my gear I bought from the $ store cork coasters full sets and of course since they were red I repainted them my world famous HD flat black. I try to repurpose anything I can to avoid paying top dollar prices. Speaker cable and i/c cords I've learned do make a difference to a point and do not skimp there.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
txcoastal1 wrote: »
I use this stuff under a lot of my gear and it works quite well. I also have a hook-up in that my dad works for a RX company in the research department as a chemist, so I have him bring home the industrial size beaker stoppers and use those as well. We've used those as risers for audio gear (and beds) due to their size and composition with great success.....
Yep, if you search for those type pads the user comments are dominated by "I use these in my audio system"...just ordered 20.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Check these out.
supplyhouse.com/DiversiTech-MP-2C-Rubber-Cork-Anti-Vibration-Pad-2-x-2-x-7-8?gclid=COW_-ouM9sUCFYSPHwodoIoAZwMain System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
