Connecting PSW10 and RTI A1s to computer
I'll admit I'm now very knowledgeable about home theatre setup so here's my first question:
- Do I need a receiver or amplifier between the computer and the sub/speakers? Or can I connect the stereo output of the computer to the Line In of the PSW10, and connect the A1s to the Speaker Level Output of the PSW10?
Thanks!
  • Jim Shearer
    Jim Shearer Posts: 369
    Just a word of caution for those who may not know:
    T-amps and (most if not all) class-D amps cannot be connected to a sub with the sub's speaker level input. Those use a BTL (or bridge tied load) topology in which all of the outputs (both positive and negative) are 'hot'. The good old direct coupled solid state (bipolar transistor) amps are fine to use with the sub's speaker level inputs.
    Cheers, Jim
    A day without music is like a day without food.
  • wearywanderer
    Thank you, I believe that answers my question!
