driving a pair of A9' with a single amp
Answers
  • Johnny816
    Johnny816 Posts: 17
    Just a thought:
    Assuming that the AVR is set for L&R speakers = Large, then you might look at the back of the Crown amp & check its settings. As a sound tech for a theater group, I know that (at least some) pro amps have a bunch of selection (option) switches on the back. One of the amps I use in our studio has a 75 Hz high pass filter option for when you want to limit low freqs--something that would kill your bass! Worth a look?
    Cheers, Jim
    Hey Jim,
    I checked the back of the crown, and no switches at all. There is a button on the front to set a few options, and when it comes to filter, I had it set to bypass it...the only filter options were bypass, low, high and crossover. From what the manual said, bypass would allow all the frequencies.
    Thanks for the thought tho
    John
