LSi15 crossover
Does Polk offer a new crossover for the LSi15's?
Best Answer
Answers
  • Buke9
    Buke9 Posts: 31
    I guess I should say that my right side crossover has fried and that is why I ask.
  • PSOVLSK
    PSOVLSK Posts: 5,380
    Or take this opportunity to upgrade the crossover is funds allow.
    http://forum.polkaudio.com/discussion/134268/polk-audio-lsi15-crossover-modification-thread#latest
    Takes the 15's to another level. Worth the price, especially since you have to spend money to replace it any way.
    F1nut Posts: 51,756
    I'll assume you fried the 5 watt resistor, a common issue. If so, just replace it with a new one of the same ohm value, but a higher wattage rating such as 10 watts. Do both crossovers.
    tonyb Posts: 33,072
    May we ask what your driving the LSI15's with ? That might also be a problem if it's not a good 4 ohm capable amp.
  • Buke9
    Buke9 Posts: 31
    I'm driving them with a Denon AVR 3310CI . I am thinking of getting a better amp soon. I'm thinking of fixing them myself first. The upgrade is a little too much for me to spend right now. Just another question if you don't mind? I pulled the post plate off and saw the resistor that was burnt. Is that the only part of the crossover or is there another section of it somewhere else and also do you pull the drivers out to get the crossover free? Thanks for your help.
    F1nut Posts: 51,756
    First off, you have an AVR, not an amp. Another AVR isn't going to be any better at driving 4 ohm speakers. If your current AVR has pre-outs you can add a two channel amp to drive the LSi15's.
    That should be the only crossover. You'll need to disconnect the wires from the drivers. Make sure to mark which wire goes where.
  • Buke9
    Buke9 Posts: 31
    When I bought them I didn't realize they were 4 ohm.They came in a package deal with a PSW 111 powered sub if you bought a certain amount so now I have two of the little subs thought they would work with my AVR setup (did not research for that purchase).
    Now I am planning on getting an amp just for them. Yes the Denon has pre's for every channel. I am thinking of buying a new DAC soon for my new headphone setup (whenever Cavalli builds my new amp) so I was thinking of making a whole other setup for the LSi15's.
  • Buke9
    Buke9 Posts: 31
    OK I got the crossover out and the resistor on the good unit is also damaged. I can't see any markings on it to find a replacement. ce0rs90qscde.jpg
    Does anyone know the part number or value of this unit. Without schematics it's hard to tell. Any help would be great.
  • Buke9
    Buke9 Posts: 31
  • Buke9
    Buke9 Posts: 31
    That was going to be my next question should I replace them all. Another thing when I look up Mills 10 or 12 watt 2 ohm resistors they don't look the same as the ones on it. Does this matter? They look like what I think a resistor looks like and not the big ceramic things that are on it. Am I looking at the right thing? Can you give me on a good place to source these ? If you don't mind. Thanks
  • DollarDave
    DollarDave Posts: 2,575
    edited May 2015
    Buke9 wrote: »
    Www.soniccraft.com
    I would replace them all.
  • Buke9
    Buke9 Posts: 31
    Thanks so much people you all help been so much help. Now all I need is 8 resistors a new roll of solder wick (and maybe a couple beers ; ) ) and I'm ready for the hunt of a new amp to run these puppies properly. But that is another subject for a different forum. Thanks again all !
