Question about DACs is it a big difference between a 24 and a 32bits?
Kinetic
Kinetic Posts: 437
edited April 2015 in Electronics
Guys, in terms of sound quality vs money.. (important the money issue)
is it a big difference between a 24 bits DAC and a 32 bits DAC?
here is why?
Im between the Marantz UD5007 ($600 dls) and the UD7007 ($1,200 dls)
Marantz technical support claims that the only difference between those two are the DAC
the UD5007 has a Burr Brown PCM1781
http://www.ti.com/product/PCM1781?keyMatch=PCM1781&tisearch=Search-EN-Everything
The UD7007 has a Burr Brown PCM1795
http://www.ti.com/product/PCM1795?keyMatch=PCM1795&tisearch=Search-EN-Everything
Extras:
I have a Marantz PM8005 integrated stereo amp
Its mainly for audio, but i choose the blu ray player since i dont want to have 2 different devices for Discs reproduction.
No. I dont want the OPPO
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Post edited by Kinetic on
  • Irrenhaus
    Irrenhaus Posts: 1,098
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Kinetic
    Kinetic Posts: 437
    mmm that doesnt tell me anything..
    Z
    Polk Audio SR 6500
    G35
  • Polkie2009
    Polkie2009 Posts: 3,834
    I'm surprised the UD5007 won't play DTS-HD HR audio??? I think even my old Sony PS3 would play my Doctor Who Blu rays encoded with DTS-HD HR audio.
  • Emlyn
    Emlyn Posts: 4,620
    The more expensive model would have greater dynamic range and a better signal to noise ratio. Doubtful that by itself the difference would be audible between the two DACs. There are more important differences including a big one which is two HDMI outputs. It also has XLR outputs. Certain elements of the internal build quality are also evident in being improved in the more expensive version.
    If the extra features are not important I would go with the cheaper option.
  • Kinetic
    Kinetic Posts: 437
    whats the use on the XLR outputs? what are they for?
    my Marantz PM8005 doesnt have XLR outputs..
    Z
    Polk Audio SR 6500
    G35
    EndersShadow Posts: 17,687
    Kinetic wrote: »
    XLR cables if used through the entire setup results in a lower noise floor and possibly a 3db increase...
  • Kinetic
    Kinetic Posts: 437
    and how can I conect them to the Marantz PM8005 integrated amp, if the amp doesnt have those conections?
    if its not possible, what would be the best way to conect them.. I was guessing a nice pair of RCAs
    Z
    Polk Audio SR 6500
    G35
    tonyb Posts: 33,065
    You would guess right.
  • Emlyn
    Emlyn Posts: 4,620
    The RCA connection method is the only one available between the Marantz Blu Ray players and the PM8005. Both of the Blu Ray players have a single set of RCA outputs. Good thing to check that these days as some less expensive Blu Ray players have no analog outputs.
  • Kinetic
    Kinetic Posts: 437
    ok and now whats to do with the Marantz UD5007 or UD7007
    the XLR is not an issue
    the 2 HDMI outputs not an issue
    just the difference between the 24bit DAC and the 32bit DAC
    is it worth the money in terms of Sound Quality?
    Z
    Polk Audio SR 6500
    G35
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited April 2015
    32 bit justifies the expense for some. :D
    Theoretically speaking, it lowers the noise floor.
    I'm guessing that if I listened to something at 32 bit then 24
    I wouldn't know which is which.
  • [Deleted User]
    lunch is almost over and I haven't found any 32/384 files to be had.
    However, I may be selling the product short as they could be oversampling
    and doing things with that.
  • [Deleted User]
    "Marantz technical support claims that the only difference between those two are the DAC" Thats a big only. :)
    I've been thinking, if this is true and I bet it isn't, then it would depend on your source
    as I was trying to say above. Some higher rate convertors do a poorer job at converting redbooks, ect. I'm told. They could be doing a better job at filtering the things you don't hear that get in the way of the things you can hear. Tough call w/out trying both w/ your source(s) What is wrong w/ the PM8005's DAC?
  • Kinetic
    Kinetic Posts: 437
    there is nothing wrong with my PM8005 DAC if I have one.. i recently bought it, i dont know much about it, and the Marantz website doesnt help..
    Im new on Home Audio..
    Z
    Polk Audio SR 6500
    G35
  • rpf65
    rpf65 Posts: 2,127
    The difference between the DACs could be substantial or meaningless. It depends are what your using for source and material, and another factor is circuit design.
    Easiest example is play an MP3 on equipment with either DAC, and probably nobody could tell the difference. Higher resolution material will be more noticeable to more people.
    One more consideration is how good your ears are. Some people can hear more nuances in music than others. If you happen to be one of those that concentrate intently on your music listening sessions, the 32 bit may be well worth it. On the other hand if your listening habits are more casual, or lean towards HT, then the extra expense may not be worth it.
    I personally don't consider myself an audiophile, but I have listened to the same manufacturers with both the DACs, and have heard a noticeable difference. I would advise trying that test. Same manufacturer, high end AVR, lowest priced 32 bit DAC, against highest priced 24 bit DAC.
  • [Deleted User]
    edited April 2015
    Yes, what he said. When I got my mid-fi DAC, it made # number of redbook CDs sound like mofi. It also made some of my punk CDs unlistenable. :s
    oh and yes of course your Marantz has a DAC. Did you end up w/ some Polk speakers?
    The crutchfield "bundle" (DAC/SACD-CDplayer) w/ some bookies and I would be a happy guy! Easy.
  • David7544
    David7544 Posts: 52
    There is absolutely no difference in sound quality between a 24 bit DAC and a 32 bit DAC. Noise floor and dynamic range are identical. The only reason for a 32 bit DAC is to play back source material which was recorded at 32 bits, of which there is virtually zero. No human on earth can hear a difference between the two bit rates, no matter what he thinks he hears. God, misinformation is annoying.
    tonyb Posts: 33,065
    Noise floor has more to do with the build in general of a dac than bits itself. There is far too many variables that go into how a dac sounds to say x doesn't matter.
  • ALL212
    ALL212 Posts: 1,644
    tonyb wrote: »
    I usually use two x's....that way it does matter. Like this.... xx as opposed to x.
    See - didn't you hear it?
    Just funnin' ya - there are about 100 other things that could make a very good 24 bit dac sound better than a badly built 32 bit. And it does sound like the more expensive model has just a few other things going for it than the cheaper model.
    Someone be BS'ing you just a little tiny xx bit.
    Aaron
    Enabler Extraordinaire
    tonyb Posts: 33,065
    LMXX off !!
    Touché bro.
  • [Deleted User]
    thanks for jumping in a year later and clearing that up for us!
    Sorry for any misinformation annoying you.
    David7544 wrote: »
  • FTGV
    FTGV Posts: 3,650
    edited March 2016
    David7544 wrote: »
    Those two DAC chips are completely different animals beyond just their bit rates.Among several other differences,one has a single ended voltage output while the other has differential current outputs.This would require a different configuration in the analog sections following them.That alone could certainly result in sound quality differences.Also the increased noise floor afforded by the 32 bit device allows for digital attenuation to be implemented without any loss of resolution.
