Putting a subwoofer into the 2 channel mix
muncybob
Would like to try the sub in my 2 channel area, nothing has a sub in jack. If I'm reading this correctly I need to run speaker wires from the amp's speaker binding posts to the 2 speakers AND another set of wires from the same binding posts to the sub's L & R speaker posts ? Do I also need to tell the cd player that there is a sub?
Yep, my name really is Bob.
Correct on the wiring. I don't believe you need to do anything to the CD player as you are sending a full range signal to the sub and using it's crossover.
