Quick Opinion Needed: NAD 3020A vs. Adcom GFA-535
lawdogg
lawdogg Posts: 469
edited March 2015 in Vintage Speakers
Wondering if either are up to the task of driving my 3.1TL's, and if so, if they'd do it any better than my Pioneer VSX-523 (modern "80W"/channel).
If not, wondering which is the better idea for my game room setup using a Technics SA-AX530 (90's 80W/channel) for the inputs. It'd be driving Snell E/III's or Paradigm 9se's usually.
Both are priced around $100-$150, the 535 was just refreshed. I just spent the last hour googling and came up with a cult-like following for the 3020 as well as generally positive opinions about the 535. They also both show up here: http://www.tonepublications.com/old-school/ten-best-buys-in-vintage-audio/
Your opinions? Either worth it? Which is better?
Thanks!
Ryan
<3 my 3.1TLs
I will fix your shifted magnets for free. :)
Post edited by lawdogg on
  • I have owned both, but not at the same time. The 3020 is an integrated amp and the 535 is a power amp. I am pretty sure the 3020A has preamp/power amp jumpers so it can be used as a power amp. The 3020 is a nice sounding & inexpensive but only 20wpc, but the 535 at 60wpc has some real "grunt". I have used it with power-hungry Dahlquist DQ-10's and Maggie MMG's and it surprised the heck out of me when paired with a decent preamp. My suggestion: If cheap enough, buy both and use the 3020A as a preamp into the 535 amp. Sell off the 535 if it doesn't make a big difference to your ear vs. the amp section already in the 3020A.
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
  • lawdogg
    lawdogg Posts: 469
    Thanks a ton for your post. I just grabbed the 3020 because it was closer, and am about to hook it up and see what all the fuss is about.
    I read somewhere that headroom is what you look for in an amp, and that the 3020 has 3db of headroom: "The 3020 may have been rated at a mere 20 watts per channel, but it had 3 dB of headroom. Hence, it could deliver 40 watts into 8 ohm loads, 58 watts in 4 ohms, and 72 watts into 2 ohms for brief periods of time."
    Then, the 535 supposedly also has good headroom (see http://www.audiokarma.org/forums/showpost.php?p=3667774&postcount=16) so maybe I will go grab it too if I'm not satisfied with the 3020.
    At this point I don't think I'll drive the Polks with it though.
    <3 my 3.1TLs
  • alkermes
    alkermes Posts: 24
    Just as an FYI, the GFA-535 is rated at 100 watts at 4 ohms, so it digs deep. It's always nice to have extra power.
    I like the idea of using the 3020 as a preamp in this setup, also.
  • leftwinger57
    leftwinger57 Posts: 2,917
    Having not heard the NAD or the Adcom either for that matter I do own both of their products. If the NAD is anything close to my 1020a pre/amp then it's a winner, whether it has enough juice to push your speakers as a stand alone amp is another story altogether. Just for informational purposes I c/pd an E-Bay for parts only 3020a.
    http://www.ebay.com/itm/NAD-3020A-150W-Stereo-Amplifier-/391093762662?pt=LH_DefaultDomain_0&hash=item5b0f013a66
