Adcom GFA-5503 common ground amp?
stoogefan00
Just bought a set of SDA-SRS that are in excellent cond. The gentlemen I purchased these from said they were the 1.2's but after delivery I noticed 13 screws in the crossover plate in front and a blade- blade connection leading me to believe I have SDA-SRS 4 ohm speakers. My question is my Adcom amp is a GFA-5503 is this amp common ground or non common ground and if it is non common ground can I run a piece of speaker wire to both neg. terminals? I checked past discussions on this but seem to find conflicting answers I'm hoping someone can help as I am a little excited to try my speakers out but at the same time I don't want to wreck them or the amp for that matter. Thank you for any time you can give me in regards to this matter.
Best Answers
It is not a common ground amp I have 3 Adcoms & the 5503 is the one of the three that is not a common ground. I have heard you can strap the terminals but not sure if I would recommend it.Home Theater
http://www.users.interport.net/a/d/adcom/manuals/gfa5503.html
The 5503 is a Mosfet amp they are not common ground you could find out and strap your terminals and try it out, but like I say I would not recommend it.Home Theater
Strapping, if possible, affects the sound quality in a negative way.Political Correctness'.........defined
President of Club Polk -
GFA-555 was a sweet match for my 2b's with a 565pre.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Go on E-Bay I bet there are a few Adcom GFA- 555's or GFA- 555II ' s those would be the ones to get, I have read a few negative reviews on the new Adcoms.Home Theater
Answers
This seems strange it seems to me some time ago I had called Adcom and talked to a rep about this and he stated after looking the specs on my amp that it was common ground this coming right from Adcom. I called him because at the time I was going to buy a set of SDA2A speakers and needed clarification but that purchase did not work out. You say you would not recommend strapping neg terminals what is my other options at this point? other than buying another amp. Also could I take an ohm meter to each of the neg terminals to check continuity to see what if any reading i am getting to also help confirm common or non common ground?
Thank you sir I will give that a try.
Why second guess you obviously have your doubts but won't accept the adcoms reps answer nor mine. I have 3 pairs of SDA'S and they will only be hooked up to my 555II or my 545II the 5503 is used for my non SDA'S as it is not a common ground amp. I can say that 3 channel 5503 does an excellent job running my fronts and center channel nice amp plenty of power.Home Theater
Thanks gudnoyez not second guessing its just when you have a high end audio lab tech and an Adcom rep along with numerous others telling you to use the 5503 because its common ground and yet others state its not I just need to know because I don't want to wreck my speakers or my amp what exactly could happen if I strap my terminals that you say you would not recommend? Why would you not recommend this is what I'm asking?
Strapping your terminals with speaker wire just don't sound like a good idea perhaps a solid pair of jumpers would be better.Home Theater
I understand and thank you gudnoyez
Thanks guys, sounds like a new amp is in order. What model Adcom amp would you recommend that would be common ground. I would like to stay with Adcom I've kinda grown to like them over the years having several models in the past. Once all this is ironed out I will post pics, right now very happy with the speakers I'm sure I'll be happier once I send them a signal.
Thanks boston1450. I was just on Adcoms sight and was looking at the GFA555SE wondering if this was a common ground amp, if so might be one to consider, what do you guys think?
Also found Emotiva XPA-2 power amp that might fit the bill if it is common ground. Either Adcom GFA555SE or Emotiva, which one?
I'll check E-bay out Thanks
I would stick with the 5503 and spring for a tyranny / Dreadnaught. IMHO, you already have the better amp, as I've had the 555II & the 5503 for years. ymmvAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Thank you GlennDog sorry I'm not quite sure what a tyranny/Dreadnaught is, do I have to make this or can I buy one. I love these SDA'S but all this is new to me when it comes to making this amp work. If I can buy one I would do that for sure. Thanks
I understand, I'll do some research and see what I can find everyone has been so helpful thanks ZLTFUL and to everyone else here trying to help me resolve this matter.
stooge, where are you located?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Illinois
I have about 6 sets of speakers in my 18'x15' living room w/my 2Bs front and center w/an equilateral triangle from my couch which is 9' from the speakers. All other sets are over on the side and do work well for the room and available space. I usually never gof on or comment on someone's listening space but dude your borderline hoarder(no you are hoarding and I'm guessing you do not hear them all). Sell the ones these guys want, you'll have the cash to get the correct amp amp and as F-NUT says that still might not be enough room for
those to breathe.
C'mon, guys.
The original poster seems to have ORIGINAL BLADE/BLADE SDA-SRS. He CANNOT use an isolation transformer. Therefore, no dreadnaught.
Testing for continuity is NOT the same as testing for resistance. A mere 20 ohms (the result of two ten-ohm resistors) between the negative terminals of my Aragon made my 1Bs unlistenable. I was lucky, no harm done to the amp or speakers...but I lost out on considerable enjoyment until I got around to strapping the negative terminals.
The Adcom 5503 in question is similar to my Aragon in that it is a common-ground amp EXCEPT for a pair of resistors which must be bypassed to use with blade/blade SDA speakers. The original poster can buy or fabricate an eight-inch jumper wire to connect the negative terminals of the amp, and he'll be JUST FINE. Those who say it affects the sound quality in a negative way has never tried to do WITHOUT the strapping on an amp/speaker combination that requires it.
Aside from replacing the speakers, replacing the amp, or going inside the amp to do "solder surgery" to bypass the resistors, strapping is the ONLY OPTION. It is simple, dirt-cheap, and instantly "reverseable" by merely yanking the wire out of the negative binding posts. There's essentially no down-side. -
Oops! Missed that B/B part . . . sorryAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Just got off the phone to Emotiva and ordered a XPA2 today should be here Thurs. so I have to wait a few more days to get my SDA SRS up and running. I guess getting these speakers was more reason to purchase a new amp and take all guess work out of the common ground problem. I did take a multi tester to both neg terminals and sure enough non common ground amp. So thanks to all for helping diagnose this problem, now I just need to find a new home for my GFA5503 and GFA5300 amps to help offset the cost of the new amp.
Sell the Communist emotiva, keep the Adcom, and put a five-dollar jumper wire between the Adcom's negative terminals. You could be enjoying those SRS speakers in an hour, and not contributing to the trade imbalance with the most hateful nation on Earth. (Less time than that, if you have some 16-gauge or heavier wire loitering around your home. You could scrape the paint off of the ends of a section of coat-hanger wire and be OK in the short-term.
Ah, the lure of a cheap amp.Political Correctness'.........defined
...and not contributing to the trade imbalance with the most hateful nation on Earth.
I agree with you but it is nearly impossible to not buy anything from China.
OP for $200 less (which leaves room for shipping) you could have had this:
http://denver.craigslist.org/ele/4914352928.html
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
To F1nut, whats your point, sorry I don't have the money to invest in a high dollar amp right now. More importantly I'm sending my daughter to a university for her degree in pathology which at this time is more important than listening to my stereo. I always try and set my priorities straight and in this case its no different. I know I could have saved money by doing what Schurkey suggested and I still can if I so desire. But for now I am going to keep this amp on order and at the very least use it upstairs in my other 2 channel system. These kind of comments are why I have been a member for so long and have never posted because there is always someone who seems to want to take cheap shots at someone who's not as fortunate as the next person. Ah, the lure of a cheap shot.
Yet, you just bought a pair of speakers and now an amp. Ah, the lure of hypocrisy......LOL
Chill out man, it's not like I had access to your financial statement.Political Correctness'.........defined
Yes I did just buy a pair of speakers that are 28 yrs old and according to you an amp that's cheap, so I guess I can afford that little bit. If there is anybody that needs to chill out its not me. I'm through with this conversation.
