DVDO VP30 video scaler with SDI and ABT102 Cards Installed
Maybe a long shot here, but I see a lot of the same IDs on several HT related forums.
Just decommissioned my NEC 10PG CRT projector, so don't need this scaler. Bought it new, using DVDO's upgrade program, replacing a HDPlus. Has the ABT102 SD upgrade card and the SDI input card installed. I used the SDI input with a Panasonic RP-82 modded DVD player, and later a Pioneer DV-79Avi with SDI. Used the SDI for video and the Pio i-link for audio. Best setup available at the time.
In any case, this machine can be used to tweak color curves and gamma for projectors or panels without that capability. Also can be used as cheap HDMI switcher.
I have the original box, manual, remote (which was only used a time or two....I use a universal) Boxes for the ABT102 card and the SDI card, power supply, firmware upgrade cables and a disc, I think. Basically, if it came with it, I have it and its included. It came out of the box, into my ventilated rack, and hasn't moved.
Looked on eBay and $200 seems about right. I'll entertain offers, of course. If you'd like a shipping quote, I'd assume 15 lbs and coming from zip 30092 - Atlanta area for pickup.
I'd also consider trades....maybe a Darblet, BDs, DVD-A's or SACDs??
My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers
  • Instant9x
    Instant9x Posts: 1
    edited March 2015
    Is this still available?
    Post edited by Instant9x on
  • rtart
    rtart Posts: 848
    Sorry..its sold. Should have updated it...sorry for the inconvenience.
    HD-A35 HD DVD
  • daboyz
    daboyz Posts: 5,207
    Hopefully one time poster will hang out and contribute some other than trying to buy something.
