Epoxy Strength Test - What's Best?
afterburnt wrote: »
Village Idiot of Club Polk
  • teekay0007
    teekay0007 Posts: 2,288
    That really shows nothing, proves nothing. That's more of a shearing strength test, and a very poorly controlled one at that. A more legit test of the strengths of these epoxies would have been to pull straight vertically on the bolts, not exert pressure from the side of the bolt.
  • Nightfall
    Nightfall Posts: 10,083
    Good to know, thanks teekay. I thought I was passing something useful on, sorry about that.
    afterburnt wrote: »
  • drumminman
    drumminman Posts: 3,396
    I thought it was interesting. The question is what is the correlation between shear strength and the other kind that teekay refers to.
    mhardy6647 Posts: 35,145
    (FWIW) If I am looking for strength, I like to use slow curing epoxy (and apply some gentle heat during the process if at all possible).
  • Speedskater
    Speedskater Posts: 495
    When it comes to epoxy, WEST System is the way to go. Available at boating shops.
    http://www.westsystem.com/ss/
